Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Forum Newbie
    AutoCAD 2013
    Mar 2015
    Colchester, Essex
    5
    Default How to add a single boundary outline around multiple hatches.
    Hi Guys,
    I'm currently working on a large scale map. The map I've purchased contains building areas as hatching but no boundary outline (to my shock). The map is laid out in tiles which has meant on many occasions buildings have been cut into 2 or more sections rather than the 1.
    I have downloaded a Merge Hatch.Lsp which merges all the building Hatches together but when I go to recreate boundary via 'HATCHEDIT' it just draws a line around each piece of hatching rather than the whole lot.
    Can anyone help me with this please, Many Thanks.
    Liam
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I think I might be able to help but you will have to change the lisp routine you are currently using to merge your hatch patterns and adopt a second lisp routine that will create a single boundary.
    CAVEAT: I've only tested this technique once using nearly square hatch patterns. Here is an image of what I did.
    Upper left corner. Two boxes created with the Rectangle command which I hatched then moved the two hatch patterns to the right assigning each a different color (yellow and blue).
    Used a lisp routine by forum member hmsilva that he graciously wrote and shared on the AutoDesk Community website and posted to the Visual Lisp...forum on 04-12-2013 to merge the two patterns. Result is shown below in green.
    Finally, used a lisp routine called Hatchb.lsp written (03-30-2000) by Jimmy Bergmark that recreates a hatch boundary. If you look at the bottom rectangle on the right you'll see a single magenta boundary that surrounds the two merged hatch patterns. I suppose there is a chance that this lisp routine will solve your problem all by itself. Might want to give it a try first.
    My test was a simple one. As the saying goes "Your results may vary."
    I'm only around for another five minutes then I have to go out into the plant. May not be back for a while.
    Last edited by ReMark; 17th Mar 2015 at 07:24 pm. Reason: can't spell today & I don't know my left from my right!
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    There was a post about 2 weeks ago and it did exactly what you want taking multiple plines and working out the single boundary of all of them you can create the hatch boundaries pretty easy. I know I replied to the post but another provided the solution will look for it soon.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,706
    The title did not really make it easy to find http://www.cadtutor.net/forum/showth...e-same-content!
  5. #5
    Forum Newbie
    AutoCAD 2013
    Mar 2015
    Colchester, Essex
    5
    Thanks Guys, I will test these out and let you know how I get on...
    Struggling to find hmsilva's lisp on the AutoCAD Community website. Do you have a link?
    When using the HATCHB.lsp along with the MergeHatch.lsp I already have I am encountering the same issues I had before.
  6. #6
    Senior Member lrm's Avatar
    lrm's Computer Details
    Windows 7 64-bit
    16 GB
    Education
    lrm's Discipline Details
    Teacher, AEC and mechanical
    Education
    Civil and Mechanical
    3ds Max 2017
    Jan 2010
    Massachusetts, USA
    380
    Here's another approach that relies only on standard AutoCAD commands. You can use this process on all hatches at the same time.
    Use HATCHGENERATEBOUNDARY to generate the boundary for all hatches then convert the boundaries to Regions then use Union to create contiguous regions from which you can use the Hatch S command to hatch the result.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    "When using the HATCHB.lsp along with the MergeHatch.lsp I already have I am encountering the same issues I had before."
    I kind of figured you would.
    Wait here, I'll be back.
    I've attached the lisp routine below. Note that he gave it the command name "test" which you will have to change. I named the lisp routine HatchMerge.lsp to differentiate it from the MergeHatch.lsp routine which I too have.
    HatchMerge.lsp
    I added two lines to the lisp routine right at the top crediting hmsilva as the author. Please do not remove them.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Quote Originally Posted by lrm View Post
    A person could die of old age using that method on a very busy drawing. Just saying.
  9. #9
    Super Member hmsilva's Avatar
    Multi-disciplinary
    AutoCAD 2016
    Dec 2012
    Cascais, Portugal
    531
    Thank you! ReMark
    Henrique
  10. #10
    Forum Newbie
    AutoCAD 2013
    Mar 2015
    Colchester, Essex
    5
    Hi ReMark, Thanks again for putting your time into this.
    I've tested the HATCHMERGE.lsp which works brilliantly on basic rectangles like your example.
    However, when using this routine on more complex shapes with numerous vertex points it purely deletes/removes them rather then merging.
  1. LISP to join multiple hatches.
    By rishabharora in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Jul 2012, 02:34 pm
  2. Multiple BOUNDARY Command with Tolerance
    By capincanuck in forum AutoCAD General
    Last Post: 15th Feb 2011, 09:31 pm
  3. Multiple sheets. Single or multiple DWG files?
    By uhcafigdc in forum CAD Management
    Last Post: 15th Dec 2010, 02:01 pm
  4. Edit multiple hatches - impossible?
    By Haggbakk in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Aug 2010, 04:21 pm
  5. Combine Multiple Hatches
    By mshearer in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Feb 2009, 05:46 pm
