wipo Posted March 20, 2015 Share Posted March 20, 2015 Greetings As you al know you can change the variable for the dimension line using Dimblk. Also Dimblk1 & DimBlk2 for each end f the dimension line. I trying to see if the there is a way that you can do the same with leaders. Have two different arrow heads by adding another leader. for example. When I have a structural detail and I wan to point to the rebar that goes the long way I used an arrow head and when the bar id just a dot I used an open circle. I can accomplish this by setting up two different styles but I would like to use just one style and just change the variable of the arrow heads if possible just like the dimension lines. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 20, 2015 Share Posted March 20, 2015 Unless you are trying to do this with code, you're making it more difficult than it needs to be. Use the properties box. Everything you've mentioned is right there and just a couple clicks away. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 20, 2015 Share Posted March 20, 2015 Welcome to CADTutor. A LEADER is considered a sort of sub class of your DIMSTYLE, so the default ARROW style in a regular QLEADER is defined by the DIMSTYLE arrow type. You can click on a leader of course and specify a different Arrow type, for that specific one either in Quick Properties or Properties. Once you have done that you can pretty quickly use the MATCHPROP command to select any you want to display similarly. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 20, 2015 Share Posted March 20, 2015 ^^ and that is from the resident variable guru. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 20, 2015 Share Posted March 20, 2015 @ wipo, what you're already doing is probably your best option. As far as I know, you can't have a single Leader/MLeader object with multiple leaders, each with their own arrowhead style... they would have to be two different Leaders/MLeaders. Example below is only one Mleader style, but one of the Mleaders has an arrowhead override applied through the Properties Palette. Quote Link to comment Share on other sites More sharing options...
wipo Posted March 20, 2015 Author Share Posted March 20, 2015 This is exactly what I need it, thx. you guys are great Quote Link to comment Share on other sites More sharing options...
wipo Posted March 20, 2015 Author Share Posted March 20, 2015 this is great but when you select add leader the second leader becomes a block with the first leader that was there. I guess in other to have different arrow head they have to be draw separated. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted March 20, 2015 Share Posted March 20, 2015 That is what Nestly said. Personally I use QLeader. It is just as easy to add leaders as it is in multileader, but they can have different heads. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 20, 2015 Share Posted March 20, 2015 this is great but when you select add leader the second leader becomes a block with the first leader that was there. I guess in other to have different arrow head they have to be draw separated. it would be a nice to have that feature, but as far as I know, if you want different arrow heads, the leader lines can't be part of the same MLeader object. Quote Link to comment Share on other sites More sharing options...
