Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 53
    Super Member
    AutoCAD 2015
    Jul 2014
    503
    Default HELP: Have hatch pattern but cannot align hatch pattern exactly.
    How to hatch so that the hex patten is at the same location as the attached drawings?
    Match properties also does not help
    hatch.dwg
    Super Member
    AutoCAD 2015
    Jul 2014
    503
    Any advise?
    Senior Member
    Manufacture
    gazza_au's Discipline Details
    Engineering
    Manufacture
    Management/Stainless Fabrication/Design/Drafting
    AutoCAD 2015
    Apr 2010
    Australia
    132
    Did you forget to attach an example of what your after ?
    Senior Member
    Manufacture
    Engineering
    Manufacture
    AutoCAD 2015
    Apr 2010
    Australia
    132
    hatch_1.dwg
    Is this what you mean?
  5. #5
    Super Member
    AutoCAD 2015
    Jul 2014
    503
    Quote Originally Posted by gazza_au View Post
    Attachment 53430
    No. Basically i can hatch with same patten but as you can see their position is not the same when you hatch it. I need it to be the same.
    Thanks
  6. #6
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Before opening the drawing, I thought for sure it was a matter of adjusting the base point but there is something weird happening when I play with it.
    Copying one of the hatches gives the desired result.
    Drafting is a breeze.
  7. #7
    Super Member
    AutoCAD 2015
    Jul 2014
    503
    Quote Originally Posted by RobDraw View Post
    Hi Rob, perhaps to add on, i have to hatch another pline of a different shape but i need the hatch to line up excately the same as the origin patten.
  8. #8
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,864
    Thank goodness we now use CAD to create drawings. It allows us to concentrate on less important aspects of our drawings.
  9. #9
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    By default AutoCAD uses (0,0), as the base point for starting a hatch. The patterns are lined up with each other. Think of it as one big hatch pattern but you are only seeing bits and pieces of it. Adjusting the position of the pattern is done by changing the origin of the pattern and can be difficult to achieve what you are saying.
    That being said, when I did that with your file I got the unexpected result of the pattern looking like it changed scales but the value did not change.
    An alternative would be move the pattern to be where you want it and then adjust the boundary to match the shape.
  10. #10
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I'm not sure how this helps.
  1. Hatch pattern error, making a "Hatch Code" .pat
    By SDSinc in forum AutoCAD General
    Last Post: 18th Jan 2011, 03:25 pm
  2. Own hatch pattern
    By Joro-- in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Nov 2009, 08:12 am
  3. Hatch Pattern
    By Hardney in forum AutoCAD General
    Last Post: 21st Apr 2009, 08:35 pm
  4. Hatch pattern
    By Carol in forum AutoCAD General
    Last Post: 25th Jan 2006, 06:28 pm
  5. How to put hatch pattern
    By Adesu in forum AutoCAD General
    Last Post: 16th Mar 2004, 07:24 am
