Dstojanoski Posted March 24, 2015 Share Posted March 24, 2015 Hello, I have problem with AutoCAD Civil 3D 2012, when I try to Save As (DXF R12/LT2 dxf (.dxf). When I choose to save in this Format, saving starts, and at the end of saving my AutoCAD crashes. I really need option to save in this format, because in that format I can Import documents to MapInfo 11.0 Anybody have problem with similar issue, how can I repair? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2015 Share Posted March 24, 2015 Dstojanoski: It is not good form to hijack another person's thread. There is a sub-forum under AutoCAD Vertical Products for asking Civil 3D related questions. In the future please post your question in the proper forum. Thank you. In regards to your question have you made any effort to clean up your drawing first by running both the -Purge and Audit commands? Quote Link to comment Share on other sites More sharing options...
Dstojanoski Posted March 24, 2015 Author Share Posted March 24, 2015 I am sorry, this is my first post here, I made mistake. Yes I tried with Purge and Audit, but still I have problem. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2015 Share Posted March 24, 2015 Did you try with the command line version of purge that is preceded with a dash? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted March 24, 2015 Share Posted March 24, 2015 I have moved this question to its own thread in the Civil 3D section: http://www.cadtutor.net/forum/forumdisplay.php?57-Civil-3D-amp-LDD Quote Link to comment Share on other sites More sharing options...
Dstojanoski Posted March 24, 2015 Author Share Posted March 24, 2015 Yes, I tried, I purge all but no effect. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2015 Share Posted March 24, 2015 Did you notice the dash in front of the command? Did you run the Overkill command on the drawing? Did you trying blocking out the drawing to a new file then do a "save as" to the DXF file format? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 24, 2015 Share Posted March 24, 2015 (edited) But, did you use -PURGE (with the dash), in particular it lets you purge Regapps, which isn't included with the ALL option of either method. It also lets you purge Zero-length Geometry and Empty text objects. Also, it will not purge them from blocks and locked layers. Do you get any error messages? Did you Export to AutoCAD first? http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Civil3D-UserGuide/files/GUID-8EC415A4-EF8E-4FDA-A54C-AA6E67CBC788-htm.html http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Civil3D-UserGuide/files/GUID-10DC3242-8763-484E-8C68-EEC48AFD0803-htm.html Edited March 24, 2015 by SLW210 Highlight information Quote Link to comment Share on other sites More sharing options...
Dstojanoski Posted March 24, 2015 Author Share Posted March 24, 2015 No I wrote only command (purge), without dash, what should i choose from options when I wrote with dash? I haven't use overkill command Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2015 Share Posted March 24, 2015 First run the OVERKILL command and select everything in your drawing. This will rid it of any duplicate or overlapping objects. Second run the -PURGE command and purge REGAPPS. Nothing else. Third run the -PURGE command and purge ALL. Fourth run the AUDIT command and say YES to AutoCAD fixing any errors. Save your drawing under a new name (for insurance purposes). Close then reopen the drawing and repeat the above but save to the current drawing name. Now try to do a "save as" to a DXF file format. Start with 2000 and see if that works before trying r12. Do you understand all of the above? Quote Link to comment Share on other sites More sharing options...
Dstojanoski Posted March 24, 2015 Author Share Posted March 24, 2015 when I run -PURGE->REGAPPS it says (Enter name(s) to purge : I don't understand what name to write? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2015 Share Posted March 24, 2015 You don't write anything. Press the ENTER key. For someone who says he has used the Purge command you don't seem very familiar with it. Quote Link to comment Share on other sites More sharing options...
eldon Posted March 24, 2015 Share Posted March 24, 2015 Perhaps you need to EXPORT to AutoCAD first. That would explode all the civil objects. Then try to save that file as R12DXF. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 24, 2015 Share Posted March 24, 2015 Where have I heard that before? Quote Link to comment Share on other sites More sharing options...
eldon Posted March 24, 2015 Share Posted March 24, 2015 Where have I heard that before? Some good advice does need to be re-iterated, even if I did not read thoroughly previous posts. Get over it, it happens all the time. Quote Link to comment Share on other sites More sharing options...
Dstojanoski Posted March 24, 2015 Author Share Posted March 24, 2015 I tried all of your tips, but still same problem. I try to save with 2000 and it save, but R12 still not work. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2015 Share Posted March 24, 2015 Did you try the export to AutoCAD advice previously given by two forum members? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 24, 2015 Share Posted March 24, 2015 Fine, I'll leave you to your own devices now. I mentioned the solution and added links to Autodesk for how to do what you want in Civil 3D and Eldon mentioned the solution and I repeated the solution. You must have me and Eldon on ignore. Quote Link to comment Share on other sites More sharing options...
Dstojanoski Posted March 24, 2015 Author Share Posted March 24, 2015 Now i tried your metod, but still same problem. Two days ago I everything was okay, but I don't know what happens now, I have this version 11 months. I'll download another version and reinstall, thanks for tips and time people, I am sorry for disturbing. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 24, 2015 Share Posted March 24, 2015 What do you mean you'll download another version and reinstall? What other version would you download? Quote Link to comment Share on other sites More sharing options...
