Bristang Posted March 26, 2015 Share Posted March 26, 2015 I am new to inventor and have started to come up against issues when I create constraints...I often times make two constraints what should allow me to slide a part but Inventor does not want me to move the part...but later it will move in the expected when creating the last constraint (is held in x and y and should slide in Z but will not...but when I do constrain it in the Z it moves)...a bit confusing... Also If I want a plane to be parallel to another plane is there a quick way to do this? I end up doing offset constraints... Thanks. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 26, 2015 Share Posted March 26, 2015 Zip and attach assembly here when you get unexpected behavior. Quote Link to comment Share on other sites More sharing options...
