anindya Posted March 29, 2015 Share Posted March 29, 2015 i have attached a sample drawing and excel sheet for kind observation please help me. NEED HELP00001.dwg NEED HELP OOO1.xlsx Quote Link to comment Share on other sites More sharing options...
VVA Posted March 29, 2015 Share Posted March 29, 2015 Try COORN-export of coordinates with numbering. Quote Link to comment Share on other sites More sharing options...
VVA Posted March 29, 2015 Share Posted March 29, 2015 NE (mleader) command (defun c:NE (/ koord xy) (vl-load-com) (while (and (setq koord (getpoint "\nPoint <exit>")) ) (setq xy (strcat "E=" (rtos (nth 0 koord) 2 3)"\nN=" (rtos (nth 1 koord) 2 3)) ) (VL-cmdf "_mleader" koord pause xy) ) ) (princ "\nType NE in command line")(princ) Quote Link to comment Share on other sites More sharing options...
anindya Posted March 29, 2015 Author Share Posted March 29, 2015 Respected sir i need to click every point one by one it will mark the coordinates(Easting & Northing) alongwith number and same time it will paste those coordinates in excel(SLNO,EASTING,NORTHING )heading.i can not do that . Quote Link to comment Share on other sites More sharing options...
anupmadhu Posted March 29, 2015 Share Posted March 29, 2015 Sir, Credits to the original programmer (defun c:coo() (princ "\nthis lsp to type the coordinate x,y & make table") (command "osnap" "cen,mid,endpoint,nea" ) (setq p(getpoint "\n Enter First Point :") pp(getpoint "\n Enter Second Point :") u(getint "\n Enter start point number:") tab(getpoint "\n Enter Upper Left Corner of Table:") u1 (+ 1 u) x(car p) y(cadr p) ; z(caddr p) x1(car pp) y1(cadr pp) ; z1(caddr pp) text(strcat "(" (rtos x 2 3) "," (rtos y 2 3)")") text1(strcat "(" (rtos x1 2 3) "," (rtos y1 2 3) ")") ;P1, P2 Distance from the Circle p1(mapcar '+ p (list 1 0.4)) p2(mapcar '+ pp (list 1 0.4)) p10(mapcar '+ p (list 1 -0.4)) p11(mapcar '+ pp (list 1 -0.4)) ; TABLE ROWLENGTH tab1(mapcar '+ tab (list 13.5 0 )) tab2(mapcar '+ tab (list 35 0 )) tab3(mapcar '+ tab (list 59.2 0 )) tab4(mapcar '+ tab (list 8 0 )) ;TABLE ROW HEIGHT tab5(mapcar '+ tab (list 0 -4.25)) tab6(mapcar '+ tab1 (list 0 -4.25 )) tab7(mapcar '+ tab2 (list 0 -4.25)) tab8(mapcar '+ tab3 (list 0 -4.25)) tab9(mapcar '+ tab4 (list 0 -4.25)) tab10(mapcar '+ tab5 (list 0 -4.25)) tab11(mapcar '+ tab6 (list 0 -4.25)) tab12(mapcar '+ tab7 (list 0 -4.25)) tab13(mapcar '+ tab8 (list 0 -4.25)) tab14(mapcar '+ tab9 (list 0 -4.25)) tab15(mapcar '+ tab10 (list 0 -4.25)) tab16(mapcar '+ tab11 (list 0 -4.25)) tab17(mapcar '+ tab12 (list 0 -4.25)) tab18(mapcar '+ tab13 (list 0 -4.25)) tab19(mapcar '+ tab14 (list 0 -4.25)) ;POINTs POISITION IN THE TABLE (P1,P2 ETC) POIN(mapcar '+ tab (list 1.9 -3.33)) POIN1(mapcar '+ tab1 (list 1.9 -3.33)) POIN2(mapcar '+ tab2 (list 1.9 -3.33)) POIN3(mapcar '+ tab3 (list 1.9 -3.33)) POIN4(mapcar '+ tab5 (list 1.9 -3.33)) ;X,Y TEXT POSITION IN THE TABLE POIN5(mapcar '+ tab6 (list 8.5 -2)) POIN6(mapcar '+ tab7 (list 8.5 -2)) POIN7(mapcar '+ tab8 (list 8.5 -2)) ;GAP (ROW HEIGHT) BETWEEN P1 TO P2 POIN8(mapcar '+ poin4 (list 0 -4.25)) POIN9(mapcar '+ poin5 (list 0 -4.25)) POIN10(mapcar '+ poin6 (list 0 -4.25)) POIN11(mapcar '+ poin7 (list 0 -4.25)) ;FIRST 2 POINTS (EX P1 + P2) uu(strcat "P " (itoa u) ) uu1(strcat "P " (itoa u1) ) ) (command "osnap" "none" ) (command "style" "rockstyle" "arial" "0.9" "1" "0" "n" "n" "n" "") (command "line" tab tab3 "") (command "line" tab5 tab8 "") (command "line" tab10 tab13 "") (command "line" tab15 tab18 "") (command "line" tab tab15 "") (command "line" tab1 tab16 "") (command "line" tab2 tab17 "") (command "line" tab3 tab18 "") ;Circle radious (command "circle" p "0.7" ) ;circle color is 10 (command "change" "l" "" "p" "c" "10" "") (command "circle" pp "0.7" ) (command "change" "l" "" "p" "c" "10" "") ;POINT 1 EX: P1 (command "text" p10 "0" uu "") ;POINT 2 EX: P2 (command "text" p11 "0" uu1 "") (command "style" "rockstyle" "arial" "2.5" "1" "0" "n" "n" "n" "") (command "text" poin "0" "POINT" "") (command "text" poin1 "0" "X" "") (command "text" poin2 "0" "Y" "") ;(command "text" poin3 "0" "Z" "") (command "text" poin4 "0" uu "") (command "text" poin8 "0" uu1 "") (command "text" "j" "mc" poin5 "0" (rtos x 2 3) "") (command "text" "j" "mc" poin6 "0" (rtos y 2 3) "") (command "text" "j" "mc" poin9 "0" (rtos x1 2 3) "") (command "text" "j" "mc" poin10 "0" (rtos y1 2 3) "") (command "osnap" "cen,mid,endpoint,nea" ) (command "osnap" "cen,mid,endpoint,nea" ) (setq ppp(getpoint "\n Enter Next Point :") ) (while ( /= ppp nil ) (progn (setq ;increase the point numbers u1 (+ 1 u1) x1(car ppp) y1(cadr ppp) ; z1(caddr pp) text1(strcat "(" (rtos x1 2 3) "," (rtos y1 2 3) ")") p2(mapcar '+ ppp (list 1 0.2)) ;Distance from the circle x=0.4, y=0.2 p11(mapcar '+ ppp (list 1 -0.2)) ;STARTING FROM P3 (4.3 is the ROW WIDTH) uu1(strcat "P " (itoa u1) ) tab15(mapcar '+ tab15 (list 0 -4.25)) tab16(mapcar '+ tab16 (list 0 -4.25)) tab17(mapcar '+ tab17 (list 0 -4.25)) tab18(mapcar '+ tab18 (list 0 -4.25)) tab19(mapcar '+ tab19 (list 0 -4.25)) POIN8(mapcar '+ poin8 (list 0 -4.25)) POIN9(mapcar '+ poin9 (list 0 -4.25)) POIN10(mapcar '+ poin10 (list 0 -4.25)) POIN11(mapcar '+ poin11 (list 0 -4.25)) );setq ;Circle radious (command "osnap" "none" ) (command "circle" ppp "0.7" ) ;circle color is number 10 (command "change" "l" "" "p" "c" "10" "") (command "style" "rockstyle" "arial" "0.9" "1" "0" "n" "n" "n" "") ;THIS TEXT EX: P3 TO N (command "text" p11 "0" uu1 "") ;TEXT FROM P3 X & Y POINTS (command "style" "rockstyle" "arial" "2.5" "1" "0" "n" "n" "n" "") (command "text" poin8 "0" uu1 "") (command "text" "j" "mc" poin9 "0" (rtos x1 2 3) "") (command "text" "j" "mc" poin10 "0" (rtos y1 2 3) "") (command "line" tab15 tab18 "") (setq pp ppp ;u1 (+ 1 u1) );setq (command "osnap" "int,cen,mid,endpoint" ) (setq ppp(getpoint "\n Enter Next Point :") ) );progn ) ;while (command "osnap" "none" ) (command "line" tab tab15 "") (command "line" tab1 tab16 "") (command "line" tab2 tab17 "") (command "line" tab3 tab18 "") (command "osnap" "cen,mid,endpoint,nea" ) );end Quote Link to comment Share on other sites More sharing options...
VVA Posted March 29, 2015 Share Posted March 29, 2015 >anindya Try to use lisp from #2 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 29, 2015 Share Posted March 29, 2015 If you want it done automatically then pick objects and just get points and write a csv file very easy. How many objects, or is it 100's Quote Link to comment Share on other sites More sharing options...
