Results 1 to 7 of 7
    Junior Member
    AutoCAD 2000
    Dec 2008
    11
    Default Automatic Polyline from Points LISP (need)
    Hi everybody,
    this is my first post.
    I need a Lisp to generate a polyline from existing points.
    The polyline should be created from all the points at the edge of the cloud of points generated by a 3d scanner.
    The points are in 3 dimensions, but they could be flatted to zero.
    The polyline can be close or open: it does not matter.
    Any idea?
    Thank you folks in advance.
    dave
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,227
    What is the order of points that the program should follow ?
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,573
    This will get you started: Convex Hull
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Junior Member
    AutoCAD 2000
    Dec 2008
    11
    Default Re: Automatic Polyline from Points LISP (need)
    Quote Originally Posted by Tharwat View Post
    Hi Tharwat,
    if I understand your question, the order is not important: clockwise or counter-clockwise does not matter.
    If there are many points on the space, I need to connect only the ones on the edge of the cloud. The points inside the cloud are not to be connected.
    I've read the suggestion of Lee Mac. This image from the page of Lee Mac is what I need to do:
    http://www.lee-mac.com/lisp/gifs/convexhull1.gif
    (hope is not a problem to point to an external link!)
    but I was not able to let the routine work properly.
    Please see attached images.
    Please take a look of attached image:
    Automatic Polyline from Points LISP (A).jpg show the "cloud" of points.
    Automatic Polyline from Points LISP (B).jpg is the "cloud" connected with a polyline.
    Now the second problem: the points are not on the same Z position! Maybe first I've to move points on an average Z position, if I want to use polylines (otherwise I must to use 3dpolyline, of course).
    Hope the answer match your question.
    Dave
  5. #5
    Junior Member
    AutoCAD 2000
    Dec 2008
    11
    Quote Originally Posted by Lee Mac View Post
    Hi Lee Mac,
    thank you for the tip.
    You can read my answer to Tharwat above.
    As I wrote, I'm not able to use Convex Hull. I'm not so good with lisp .
    I've tried to copy and paste the code in your page, with the usually "nil" at the command line...
    How to use it?
    Dave
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,573
    Quote Originally Posted by daveacad View Post
    How to use it?
    You would first need to download & load (e.g. via AppLoad) the Convex Hull function from the download link at the top of the page; and then copy the code for Example Program 1 either to a .lsp file, or to the AutoCAD command-line. The command for the example program is then 'test1'.
    However, given that your example images show the desired result is not entirely convex, this function will only get you part of the way there.
    Lee
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,603
    You need some form of a Boundary lisp I am struggling a bit at the image scale but it looks like you want two parallel lines formed from the strip of points.
    Is there not cloud tools to do this ?
  1. points of a polyline lisp routine
    By Emily_83 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Oct 2017, 02:08 pm
  2. HELP: Any LISP to remove all the points/vertices of a polyline
    By vernonlee in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2015, 09:39 am
  3. Looking for a LISP routine that places points on all vertices of a polyline?
    By tzframpton in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jul 2013, 11:15 pm
  4. Automatic Join Polyline onto existing Polyline ??
    By Leave Me Here in forum AutoCAD Beginners' Area
    Last Post: 19th Sep 2011, 12:13 am
  5. Automatic Extraction of Elevation Properties of Points on a Line
    By skipo4us in forum AutoCAD Drawing Management & Output
    Last Post: 15th Mar 2008, 05:46 am
Tags for this Thread
