Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2012
    Sep 2014
    7
    Default Dynamic Blocks - Rotation
    Hi there, hopefully this is just me being dumb.
    What I have is an object that I have made into a block,
    It has a vertical component, which can rotate 6 deg. clockwise and 11 deg. anti-clockwise.
    Problem is, I need to limit the rotation 11 deg one way 6 the other, as the default location needs to stick at vertical.
    The rotation parameter, as far as I have experienced, only allows me to limit movement in one direction, so it can rotate 17 deg. clockwise. Or 17 deg. anticlockwise.
    What am I doing wrong?
    Thanks
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,116
    You can limit the rotation between 2 angles - minimum and maximum. Can you post a copy of the block it would be easier to answer if someone can actually see what you are trying to do.
    Forum Newbie
    AutoCAD 2012
    Sep 2014
    7
    Hi there,
    Attached is a quick file that illustrates the problem.
    As you can see, I have limited the range that it can move, but for some reason which is likely my fault, it only rotates one way with the range set.
    Which would be fine were it not that the default location needs to be vertical, not at the base.
    Hope this makes more sense
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,116
    Is this something like, what you want to do. Or do you need to use actual negative values for the input.
  5. #5
    Forum Newbie
    AutoCAD 2012
    Sep 2014
    7
    Steven,
    That's exactly what I wanted to do, thank you.
    I can see what I was doing wrong now. - aka I was doing it completely wrong.
    Brilliant this has been annoying me for a few days and I couldn't find any relevant/useful info that told me how to do it correctly.
    Thanks again,
  6. #6
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,116
    You weren't far off, all I did was adjust a few of the angles in the properties toolpalette.
  7. #7
    Forum Newbie
    Construction
    Plant 3D 2017
    Jan 2018
    1
    Default DynamicBlock_RotationLimits
    Steven,
    I looked at the example you supplied for Karnak.
    I am not seeing how to accomplish ( see attached file for what I am trying to accomplish ). I would appreciate any help.
    Thanks
    -lm
  1. Dynamic Block Rotation
    By RFRUSSO in forum AutoCAD Drawing Management & Output
    Last Post: 31st Mar 2014, 04:23 pm
  2. Dynamic block with Atribute rotation
    By notkathrine in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Nov 2013, 08:31 pm
  3. dynamic blocks and reverse rotation actions
    By cholpuch68 in forum AutoCAD Drawing Management & Output
    Last Post: 14th Dec 2012, 03:16 pm
  4. Dynamic Rotation
    By TWCameron in forum AutoCAD Drawing Management & Output
    Last Post: 18th May 2010, 07:22 pm
  5. rotation parameter (dynamic blocks)
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 27th Feb 2008, 08:42 am
Tags for this Thread
