Results 1 to 6 of 6
    Full Member
    AutoCAD 2012
    Apr 2015
    48
    Default VBA dynamic blocks edit
    Hi, iv got the below vba in progress, i copied it from somewhere online but cannot remember where to give credit
    Anyway iv got it running from a userform but it will only update the last block inserted. Eventually i want to use it to control 5+ dynamic block, also with visibility states but im at a loss after trying multiple things over the last few hours. Can someone point me in the right direction please?
    Code:
    Public Sub block_dyn()
    Dim objBlock As AcadBlockReference
    8
    Dim FilterType(0) As Integer
    Dim FilterData(0) As Variant
    Dim p1(0 To 2) As Double
    Dim p2(0 To 2) As Double
    Dim ssetObj As AcadSelectionSet
    On Error Resume Next
    ThisDrawing.SelectionSets.Item("SS1").Delete
    Set ssetObj = ThisDrawing.SelectionSets.Add("SS1")
    FilterType(0) = 0
    FilterData(0) = ""
    ssetObj.Select acSelectionSetAll, p1, p2, FilterType, FilterData
    For Each Item In ssetObj
        If objBlock.EffectiveName = "Box" Then
            Set objBlock = ssetObj.Item(n)
            Call dyn_prop(objBlock, "Width", TextBox3.Value)
            Call dyn_prop(objBlock, "Height", TextBox4.Value)
        End If
        If objBlock.EffectiveName = "Rect" Then
            Call dyn_prop(objBlock, "Thickness", TextBox3.Value)
            Call dyn_prop(objBlock, "Depth", TextBox4.Value)
        End If
    Next
    End Sub
    Public Sub dyn_prop(objBlock As AcadBlockReference, name_of_property As String, value_of_property As Double)
    Dim dyn_properties() As AcadDynamicBlockReferenceProperty
    Dim var_atts As Variant
    var_atts = objBlock.GetDynamicBlockProperties
        For i = LBound(var_atts) To UBound(var_atts)
            If var_atts(i).PropertyName = name_of_property Then
                var_atts(i).Value = value_of_property
                ThisDrawing.SendCommand "_regen" & vbCr
            End If
        Next
    End Sub
    Thanks in advance
    ~D
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    My $0.05 I just manage to do VBA stuff your selection set is looking at all of the dwg.
    Code:
    FilterDXFCode(0) = 0
    FilterDXFVal(0) = "INSERT"
    'FilterDXFCode(1) = 2
    'FilterDXFVal(1) = "SCHEDTEXT"
    Set SS = ThisDrawing.SelectionSets.Add("pit1sel")
    SS.Select acSelectionSetAll, , , FilterDXFCode, FilterDXFVal
    ' also if you pick one block then something like this
    attribs = SS.Item(Cntr).GetAttributes
         If attribs(0).TextString = pitname Then
           pt1 = ThisDrawing.Utility.GetPoint(, " pick first point")
           txtx1 = CStr(FormatNumber(pt1(0), 3))
           TXTY1 = CStr(FormatNumber(pt1(1), 3))
            attribs(1).TextString = txtx1
            attribs(2).TextString = TXTY1
            attribs(1).Update
            attribs(2).Update
    '        ThisDrawing.Application.Update
    Full Member
    AutoCAD 2012
    Apr 2015
    48
    so i got the vba changing multiple blocks in the drawing with the code below.
    my next part is to change the visibility state but i cannot find any info anywhere on doing this.
    My aim is to create a userform with tickboxes which will set the visibility state
    Any ideas?
    Code:
    8
    FilterType(0) = 0
    FilterData(0) = "INSERT"
    Dim n As Integer
    n = 0
    'For Each Item In ssetObj
    While n < ssetObj.Count
            'Set objBlock = ssetObj.Item(n)
            Call dyn_prop(objBlock, "Width", 100)
            Call dyn_prop(objBlock, "Height", 100)
        End If
            Call dyn_prop(objBlock, "Thickness", 150)
            Call dyn_prop(objBlock, "Height", 150)
        End If
        n = n + 1
    Wend
    'Next
        'ThisDrawing.SendCommand "_regen" & vbCr
    End Sub
            End If
        Next
    End Sub
    Forum Newbie
    rexxitall's Computer Details
    Windoze 7
    Homebrewed
    Asus server mainboard
    Intel core i7
    64 GB
    3. nvidea quaddro 4000
    Solid state
    Seagate 4 TB
    2x Siemens widescreen
    Civil
    rexxitall's Discipline Details
    construction engineer
    Civil
    Mainly i work on bridges, power plants, factorys, railway systems
    AutoCAD 2007
    Feb 2015
    Gerrmany / Finland
    4
    Default visibility
    Code:
    those routines are known as working.
    to set a parameter just give its value as text string
    so e.g. the visibility state name
    instead of sentcommand try
    thisdrawing.renegen all
    best regards
    Function block_set_parameter(blockref As AcadBlockReference, ByVal NAME As String, VALUE As Variant, Optional ucaseName As Boolean = True) As Boolean
        block_set_parameter = False
        If blockref Is Nothing Then Exit Function
        Dim DynProp As AcadDynamicBlockReferenceProperty
        Dim PROPNAME As String
        Dim Variable As Variant
        Dim temp As String
        Dim BV As Variant
        If ucaseName Then NAME = UCase(NAME)
        Variable = blockref.GetDynamicBlockProperties
        For K = LBound(Variable) To UBound(Variable)
            Set DynProp = Variable(K)
            PROPNAME = DynProp.PropertyName
            If ucaseName Then PROPNAME = UCase(PROPNAME)
            'Check for variable and when found ask for input
            If PROPNAME = NAME Then
                If DynProp.ReadOnly = False Then
                    BV = DynProp.VALUE
                    err.Clear
                    If DynProp.VALUE <> VALUE Then
                        DynProp.VALUE = VALUE
                    End If
                    If err.number = 0 Then block_set_parameter = True
                    On Error GoTo 0
                    err.Clear
                    Exit Function
                End If
            End If
        Next
        On Error GoTo 0
    End Function
    Function block_get_parameter(ByRef v As Variant, blockref As AcadBlockReference, ByVal NAME As String, Optional ucaseName As Boolean = True) As Boolean
        Dim temp As String
        block_get_parameter = False
        If blockref.IsDynamicBlock Then
                    block_get_parameter = True
                    v = DynProp.VALUE
                    Exit For
                End If
            Next
        End If
    End Function
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Please read the Code Posting Guidelines and edit your post to include the Code in Code Tags.
  6. #6
    Forum Newbie
    Windoze 7
    Homebrewed
    Intel core i7
    64 GB
    Solid state
    Seagate 4 TB
    Civil
    Civil
    AutoCAD 2007
    Feb 2015
    Gerrmany / Finland
    4
    Quote Originally Posted by SLW210 View Post
    Happy now ?
  1. Dynamic Blocks, Attributes w/ Visibility States, and Attribute Edit
    By rayg11757 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Mar 2018, 05:11 pm
  2. How to Edit Dynamic Blocks
    By Tahir Qayyum in forum AutoCAD Drawing Management & Output
    Last Post: 28th Oct 2014, 11:40 am
  3. Insert dynamic block from file with multiple dynamic blocks
    By BUrBaKy in forum AutoCAD Drawing Management & Output
    Last Post: 14th Nov 2012, 11:38 pm
  4. Edit Dynamic Block using VBA
    By TheBrain in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Oct 2009, 09:22 am
  5. Can I edit BlockPlaceholder in dynamic blocks?
    By Lindsay in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jul 2008, 06:00 pm
Tags for this Thread
