bennyboy86 Posted April 1, 2015 Share Posted April 1, 2015 hi all, so started at a new job, and am using cad lt 2014, and have come across a problem haven't seen since 2011, when i hatch an area, using the pick points option, cad has a heart attack and craps out, have tried changing a couple of settings like HPLGMODE and HPQUICKPREVIEW, but doesn't help the issue, if i go draw poly lines around everything i need to hatch that tends to work but takes ages as im drawing around kitchen equipment......thanks for your help...also my computer specs are attached.... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 2, 2015 Share Posted April 2, 2015 Could the hatch boundaries be an XREF? Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 2, 2015 Share Posted April 2, 2015 The hatch scale may be too fine. Or maybe the boundary probably is leaking at the seams, and the program runs out of brain cells trying to hatch all of modelspace. Fillet the corners with a zero radius, extend perp lines to the line you "think" they are touching, etc., etc. Does 2014 show any little red circles at the error points in the boundary, or is that a new thing in 2015? Quote Link to comment Share on other sites More sharing options...
bennyboy86 Posted April 2, 2015 Author Share Posted April 2, 2015 answers: a. im in my xref trying to create said hatch b. fully closed boundary, no little circles pop up made sure of that........and hatch scale not small.........those red circles been around a while think longer then 2015...... Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 2, 2015 Share Posted April 2, 2015 Can you post a copy of the drawing, maybe take out as much of the content as you can leaving only a few areas that won't hatch. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 2, 2015 Share Posted April 2, 2015 Is your version of LT 2014 current with the latest service pack? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 2, 2015 Share Posted April 2, 2015 answers:a. im in my xref trying to create said hatch Clear this up for me, please. Are you actually in the XREF file or are you making a hatch in the hosting file using objects in the XREF as boundaries? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 2, 2015 Share Posted April 2, 2015 I would also like you to clarify about the XREF, as mentioned by RobDraw. It has been a problem since I can remember, one little thing in the drawing that AutoCAD doesn't like when hatching with pick points and BAM, it freaks out. I never seem to have a problem in drawings I start from scratch, just older drawings by others. You can use LAYISO to alleviate the problem sometimes. I would go through and check all the Hatch related System Variables, particularly HPGAPTOL HPANG Sets the angle for new hatch patterns. •HPANNOTATIVE Controls whether a new hatch pattern is annotative. •HPASSOC Controls whether hatches and fills are associative. •HPBACKGROUNDCOLOR Controls the background color for hatch patterns. • HPBOUND Controls the object type created by HATCH and BOUNDARY. •HPBOUNDRETAIN Controls whether boundary objects are created for new hatches and fills. •HPCOLOR Sets a default color for new hatches. •HPDLGMODE Controls the display of the Hatch and Gradient dialog box and the Hatch Edit dialog box. •HPDOUBLE Specifies hatch pattern doubling for user-defined patterns. •HPDRAWORDER Controls the draw order of hatches and fills. •HPGAPTOL Treats a set of objects that almost enclose an area as a closed hatch boundary. •HPINHERIT Controls the hatch origin of the resulting hatch when using Inherit Properties in HATCH and HATCHEDIT. •HPISLANDDETECTION Controls how islands within the hatch boundary are treated. •HPISLANDDETECTIONMODE Controls whether internal closed boundaries, called islands, are detected. •HPLAYER Specifies a default layer for new hatches and fills. •HPMAXLINES Sets the maximum number of hatch lines that are generated in a hatch operation. •HPNAME Sets the default hatch pattern name. •HPOBJWARNING Sets the number of hatch boundary objects that can be selected before displaying a warning message. • HPORIGIN Sets the hatch origin point for new hatch patterns relative to the current user coordinate system. • HPORIGINMODE Controls how the default hatch origin point is determined. •HPQUICKPREVIEW Controls whether to display a preview when specifying internal points for a hatch. • HPSCALE Sets the hatch pattern scale factor. • HPSEPARATE Controls whether a single hatch object or separate hatch objects are created when operating on several closed boundaries. • HPSPACE Sets the hatch pattern line spacing for user-defined patterns. •HPTRANSPARENCY Sets the default transparency for new hatches and fills. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 2, 2015 Share Posted April 2, 2015 I never seem to have a problem in drawings I start from scratch, just older drawings by others. +1 to that. I hate working on other people's drawings. Nothing but problems. Further to what others have said, make sure to PURGE and AUDIT the drawing and any Xrefs you have attached to your drawing. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 2, 2015 Share Posted April 2, 2015 A great majority of the files that I work on are from others. Some of the stuff I see just amazes me. Quote Link to comment Share on other sites More sharing options...
bennyboy86 Posted April 6, 2015 Author Share Posted April 6, 2015 hi guys sorry was easter long weekend its not my original drawing All work is done in the XREF file, only thing in actual drawing is the xrefs and title page......tried purges and audits, will go through SLW210's settings and try them out program is autocad LT 2014.....but used to have the same issues on autocad 2011..... have had it happen on drawings someone else has done and on my own........ thanks for the help so far Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 7, 2015 Share Posted April 7, 2015 I'm still not clear as to where the hatch is being created and if the boundaries are from an XREF. Either way, you may have to drop the pick point option. If the boundary is complicated, i.e. blocks/nested blocks that have 3D elements, especially if it utilizes objects from an XREF'd file, AutoCAD is not going to like that. The only way that I know of to get the hatch to work in these cases, is to create your own boundary. Quote Link to comment Share on other sites More sharing options...
bennyboy86 Posted April 14, 2015 Author Share Posted April 14, 2015 yeah rob that is what i am doing, for basic areas it handles it but anything with a curve need to draw my own poly line and all good. gone through all those settings and still screws up so doing it the manual way.... and to clarify, all line work including hatching is done in the one drawing, then xref'ed into the actual drawing, with the title block, etc...... Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 14, 2015 Share Posted April 14, 2015 Attach a copy of this drawing to your next post as it seems we are just spinning our wheels at this point. Quote Link to comment Share on other sites More sharing options...
