Arguing with a Fish
Netminder
While closing out some assembly drawings and parts to make room on my parts ribbon I was given a "Autodesk Inventor Professional 2013 - ! Encountered an Improper Argument" code.
Nothing seems to turn off this error code and no other functions are allowed.
I looked the code up in the Ascent textbook that I have but nothing was there.
Is there a way around this or do I have to close the program?
I am unsure when my last save was and don't want to lose my work.
Any ideas?
Thanks,
Scott
This is a serious error.
Are you using Projects (*.ipj)?
Are you saving locally or to network drive.
I would reboot the computer.
Save often!
You should never be, "...unsure when my last save was".
I tell my students, "Every time you do something right - save it."
Your file could even be corrupt.
The Oldversions might be only recourse.
Lesson learned.
I was working in .ipt and .iam. I've never worked in .ipj.
Luckily, when I rebooted I found that I had saved all parts and assemblies. The files are all saved to our network drive.
"Save Often!" is the motto that I tell our group regularly but I've been on a 18 hour drawing binge and had lost track.
Thanks for the response!
Scott
... I've never worked in .ipj.
Scott
If you are not using Vault, I recommend that you learn how to set up Project(s) for your work.
It will save you lot's of headaches. Takes less than 60 seconds.
