TC4201 Posted April 2, 2015 Share Posted April 2, 2015 running auto cad 15. the layout tabs at the bottom of the screen. I will click on the first lay out tab to work in it, so i look up into model space. then when i look back down at the layout tabs, it has moved to the last tab. If i'm working in a middle layout tab, the look down and it has moved to the last tab. guessing my question is. Why / how are the layout tabs moving without me manually moving the tab. by manual i mean if i want to move a tab i press down left mouse and drag and drop... Quote Link to comment Share on other sites More sharing options...
Commandobill Posted April 2, 2015 Share Posted April 2, 2015 Here is a good location with that exact issue. If you look through you will find a "hotfix" that should fix the issue. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 2, 2015 Share Posted April 2, 2015 Hah! that's funny. I just installed that hotfix about 5 minutes ago. Instead of going to another forum and scrolling through the thread to find the link, here's the hotfix: http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-C2-AE-autocad-C2-AE-2015-layout-tab-order-shifting-hotfix.html?v=2015 Quote Link to comment Share on other sites More sharing options...
