KATIE0801 Posted April 6, 2015 Share Posted April 6, 2015 Hi The multileader shows up to scale in the viewport. But when i change the position of the multileader or change the width of the text box these ammendments do not show up in viewport? Katie Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 6, 2015 Share Posted April 6, 2015 Different annotation scales for model space and viewport? Quote Link to comment Share on other sites More sharing options...
KATIE0801 Posted April 7, 2015 Author Share Posted April 7, 2015 Thanks. I am now editing inside the vport instead and working so far. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 7, 2015 Share Posted April 7, 2015 Okay, as long as you are satisfied with not finding out why it doesn't work in model space. Quote Link to comment Share on other sites More sharing options...
Dana W Posted April 7, 2015 Share Posted April 7, 2015 Each annotative object will only respond to those simple type moves or edits in the current scale, if that scale is assigned to the object. Complete moves will show up in all scales. It is how they work. Make your adjustments through an active viewport, as you have discovered, OR change the annotative scale in modelspace. There should be a pop up list for that, similar to the one on the taskbar for viewport scaling. 2010 does have that, right? That way, the fitment can be adjusted for the crowding that occurs at smaller scales without it affecting the appearance in other scales. 1:20 is more crowded up than 1:10, for instance. Quote Link to comment Share on other sites More sharing options...
MonkeyTurnip Posted April 14, 2015 Share Posted April 14, 2015 do a regenall in paperspace, sometimes AutoCAD Doesn't update the view correctly when switching spaces, and a regenall should solve that. depending on how many layouts and or viewports it can take a couple of seconds to perform. and save before you run the command, I have had heavy drawings crash when performing this command Quote Link to comment Share on other sites More sharing options...
