Nickkot Posted April 6, 2015 Share Posted April 6, 2015 Hello. This is my first post. I am learning Inventor with the aim of modelling boats. The work flow I am attempting is: Create 2D sketches of the side and top profile Create 3D intersection curve for the deck edge Create 2D hull profiles on multiple parallel planes Loft surfaces over the hull profiles. This works for me for simple forms but more complex forms almost always fail to loft. I think the issue is that the geometry is not all connected. When I zoom in on the work points that I have created by intersecting the parallel plans with the 3D curves, they do not always lie on the curve so that the loft profile is not connected to the rail. The points that I create in one plane are not active in others and the points I create in 2D are not active in 3D and vice versa. I am using Project Geometry to connect to them. Can anyone help me out? Nick. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 6, 2015 Share Posted April 6, 2015 Wouldn't you be better off using boat design software rather than Inventor? Quote Link to comment Share on other sites More sharing options...
Nickkot Posted April 6, 2015 Author Share Posted April 6, 2015 Inventor does a lot I'm interested in so I'm running with that. I work a lot with both wood and metal but for now I am interested in boat hulls. Any help on my question? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 6, 2015 Share Posted April 6, 2015 ... I think the issue is that the geometry is not all connected. When I zoom in on the work points that I have created by intersecting the parallel plans with the 3D curves, they do not always lie on the curve so that the loft profile is not connected to the rail.... Nick. This behavior does not sound correct. Attach *.ipt file here that exhibits this behavior. Quote Link to comment Share on other sites More sharing options...
Nickkot Posted April 6, 2015 Author Share Posted April 6, 2015 Well. I've spent so many hours in the last week trying to get this to work and didn't bother saving the fails and now I sketch up another and it worked perfectly! I attach the file anyhow.. Nick. Boat loft.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 6, 2015 Share Posted April 6, 2015 Well. I've spent so many hours in the last week trying to get this to work and didn't bother saving the fails....Nick. It is the failures that offer the best opportunities for learning. Quote Link to comment Share on other sites More sharing options...
Nickkot Posted April 6, 2015 Author Share Posted April 6, 2015 It is the failures that offer the best opportunities for learning. So true! But I would like to know what I was doing wrong.. A question about the 3D intersect line: When I tried deleting the original defining lines an error message resulted. I note that the 3D line is always yellow not black although I couldn't find out the meaning of this. Do intersect lines depend on the original defining geometry or can they be converted to lines like any other? Thanks Nick. Quote Link to comment Share on other sites More sharing options...
