Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie
    Mechanical 2015
    Apr 2015
    6
    Default convert cloud of points or mesh into surface
    Hello,
    I am using Matlab to create a surface I import into Autocad Mechanical 2015.
    Matlab uses a library to convert a matrix into a .dxf 3D surface. Depending on the option, the surface is either a cloud of points, or made of triangles or square patches (linking the points). (files attached)
    I can open these files with AutoCAD Mechanical and even export them in other formats (ie. stp), but I would like to convert the cloud of points or the triangles mesh into a surface (mostly to reduce the size of the file).
    For now I have 4 millions points (which gives me a 19MB .stp file when I export the triangle mesh .dxf file into .stp). I am planning to increase the resolution... So it is not possible to keep all the points and triangle meshs and I hope that there is a way to replace the meshs and points into a surface in order to make it easier to handle by AutoCAD, and lighter to export. (I need to export it in .stp (or similar format) so it can be used by an electromagnetic simulation software (HFSS, CST...)).
    How can I do with Autodesk product design suite ultimate 2015?
    (AutoCAD Mechanical, Inventor pro...)
    Best regards,
    Fabien
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I managed to create a single surface (one object) using your triangle_mesh.dxf file. Is that what you are looking for? BTW....the saved file size is 9.32MB.
    Forum Newbie
    Mechanical 2015
    Apr 2015
    6
    It is better than what I managed to do! How did you do to convert the mesh into a surface?
    However, this element is only a small cell of 2mm x 2.2mm. I will need to create a bigger surface by duplicating the cell several times (to make a complete grating, of 50mm x 50mm, I would have to duplicate it more than 500 times... Maybe I will start smaller though!). Anyway, it would be good if it were possible to reduce the file size even more.
    Thank you!
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    This is how I did the conversion.
    I first made sure the system variable FACETERSMOOTHELEV had a value of "0". Next I used the CONVTOMESH command to convert the polygon mesh to a regular mesh. Finally I used the CONVTOSURFACE command to convert the mesh to a surface.
    I can foresee problems duplicating the surface 500 times. The file size will big immense. Hope you have a brute of a computer.
  5. #5
    Forum Newbie
    Mechanical 2015
    Apr 2015
    6
    I just tried that. (well, first I had to download the English package for AutoCAD because I realised that the name of the commands change depending on the language of the version...).
    The CONVTOSURFACE command lasted for almost an hour. The result is a surface, but quite an heavy one! (about 200MB when I export it in dwg or sat or igs). As you can see attached (pict), when creating the surface, a lot of lines were created to interpolate the points. I should be why the file is so big.
    I tried PURGE, setting PROXYGRAPHICS to 0 or converting the surface to NURBS, it didn't change the size.
    Why is the size so different to what you obtained? In what format did you export it?
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Who said anything about exporting the drawing? I got as far as creating a surface, as per your request, then saved the drawing. That was all I did.
  7. #7
    Forum Newbie
    Mechanical 2015
    Apr 2015
    6
    In fact, I saved it (in dwg) and also exported it (in sat and igs). But even the saved file in .dwg is 195MB big. So, it seems like my surface is a lot heavier than yours, even though I used the same commands. I am trying to understand what happened. I attached a picture of my surface so you can compare to what you obtained. Do you also have so many lines interpolating the points? In what format did you save the file?
    Thank you very much for helping me.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Repeat: My saved drawing file (2010 file format) was less than 10MB. I don't know what you are doing that accounts for the almost 20 fold increase you are getting.
  9. #9
    Forum Newbie
    Mechanical 2015
    Apr 2015
    6
    Thanks, but you don't have to repeat. As I wrote in my previous post, I was trying to understand why I wasn't obtaining the same file size as you.
    I finally found out. There is a variable : SMOOTHMESHCONVERT which has to be set to 3 (or maybe 2). So, AutoCAD doesn't try to smooth the surface. By default it is set to 0, which results in a really long execution time and gives a smooth but really heavy surface.
    Now, the command is exectuted in 1s and I get a 9.8MB .dwg surface file, like you. Thanks for your help
  10. #10
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    You don't need to download an English version of AutoCAD or even a laguage pack if you are using a non English version. Just preceed the English command with an underscore character e.g. "_CONVTOMESH"
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  1. Lisp : Convert Polyline to Cloud
    By mfadzli in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2015, 09:17 am
  2. how to create surface from point cloud
    By cios106 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Sep 2013, 03:14 pm
  3. Convert a point cloud or DTM to a surface or solid
    By Tyke in forum Civil 3D & LDD
    Last Post: 17th Nov 2010, 03:07 am
  4. CONVERT PLANAR SURFACE TO MESH autocad
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Oct 2008, 11:18 am
  5. Generation of 3D surface from 3D cloud of points
    By suga in forum AutoCAD Drawing Management & Output
    Last Post: 19th May 2005, 07:44 am
Tags for this Thread
