Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2012
    Mar 2015
    6
    Default Point files to colored contour maps-Please help!
    Good morning,
    I'm typically running ACAD 2013 with a big focus in 2D drafting. Recently the purchase of survey equipment has given me a "baptized by fire" introduction to Civil 3d. I was given point files of surveys. I was told to use a grid surface as opposed to TIN surface. So here is where the issues start.
    1) I can't figure out how to upload point groups to grid surfaces in the toolspace
    2) When I do use a TIN surface(just to try to get something) the triangulation cuts corners on my survey. This is quite apparent when I upload the point group to the TIN surface and overlay the contour surface over the points.
    3) The end result needs to be a plan view of a colored contour map with contour lines that divide depths and give a sounding (think I got the labeling of depth with the tags).
    What is the quick easy fix? Is there something I'm not understanding? I've looked at all kinds of youtube videos but nobody seems to show me what I need. Thanks a million for any/all help!
    Forum Newbie
    AutoCAD 2012
    Mar 2015
    6
    Well, I've fought my way to a plan view with colors and contour lines. The only thing I haven't figured out is to make a plan view look more realistic and 3d if you will. My image has defined lines and colors and I'm looking to try and blend the colors so the transition between elevations is smooth. Any thoughts?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    I moved your thread to the Civil 3D & LDD Forum.
    Please post Civil 3D & LDD related questions there.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    If your using a contour style with "Shade" you can change the number of colours to be used giving more subtle change between levels.
  5. #5
    Forum Newbie
    AutoCAD 2012
    Mar 2015
    6
    By contour style I'm assuming you are referring to the surface style located under the information tab in the surface properties? I've chosen contours 2' and 10' (design) for my surface style and made sure "elevations" were turned on in the display. I still can't figure out how to add colors. I've gotten pretty familiar with the navigation of surface menus so if you could point me in the right direction I would certainly appreciate it. Thanks again!
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    There is an option "Rainbow' will find it you can increase the number of colours.
  1. Colored surfaces
    By nikson in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th Dec 2014, 04:15 am
  2. Linking end point lines - creating a contour.
    By CafeJr in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2013, 11:07 am
  3. Colored background.
    By Ibrahim in forum AutoCAD General
    Last Post: 9th Dec 2011, 11:41 am
  4. google maps/live maps as xref/underlay.
    By OMEGA-ThundeR in forum AutoCAD General
    Last Post: 12th Jun 2009, 02:45 pm
  5. 3d colored shapes coming out white with colored outline
    By jojoma in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2008, 06:02 am
