Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2015
    Apr 2015
    1
    Default Colors for plot styles missing in Plot Style Table Editor - AutoCAD 2015 MAC
    Hi,
    I've just started using AutoCAD and would need to print out my first piece of work. I'd like to create a new plot styles so that my layer colors don't print as displayed (i.e. I want my blue, red and white layers to print as black and my green layer to print as yellow).
    According to all tutorials/instructions I should get a long list of colors (color 1, color 2, color 3 etc) under "plot styles" in the plot styles table editor. However, there are no colors there. Just one that says "normal". How can I choose which layer color to print as what color if I have nothing to choose from?
    I have attached a screen shot of my plot style table editor.
    Please could anyone help? I'm using a student version of AutoCAD 2015 (version J.51.M.256)
    Thanks,
    Sofia
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,797
    The solution below is straight out of AutoCad Help (F1 key) for Windows. It should be the same for Mac. This is a pretty basic legacy function in AutoCad, so I can't imagine them changing it just for the Mac. If it does not work, or does not have the same command(s), hit F1 and search for stb. Something there will be helpful.
    I noticed your plot style is unnamed.stb. Plot styles ending in the .stb extension are not color dependent plot styles. You probably will have to convert the drawing you are using, to work with color dependent plot styles, those that end in .ctb extension. Color dependent plot styles can react to the incoming object color, and plot different colors and line weights instead of the incoming properties. Once you convert the drawing you will see the .ctb extension on the available plot style list.
    Then you can edit one of the plot styles to plot the output color and/or line weight based on the incoming (existing) object color. Do not permanently change the plot styles that come with AutoCad, Save As... a new plotstyle.
    I suggest starting with acad.ctb, the default color plotstyle. It will currently plot all existing colors without changing anything, and prints every lineweight as the default lineweight. It is up to you to customize it and save it as a new plotstyle table (New.ctb file).
    Solution to use color dependent plot styles:
    The drawing has been associated with STB styles. To resolve this, enter CONVERTPSTYLES in command line. A dialog box will show up notifying you that your named plot styles will be removed and that the drawing will be converted from named plot style to Color Dependent mode.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,180
    That is unless you would like more functionality out of your plotting. CTBs are easy to use but there are advantages to using STBs. Educate yourself on the differences and make an informed decision as to which on you want to use.
    Drafting is a breeze.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,599
    If you want to stay with the STB simply add two styles for your current problem, one for black and one for color, assign the black one to the layers you want to plot black and the color for the other. Edit each to plot the color you are wanting.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Missing Plot Styles - poof it's gone!
    By AmandaK in forum AutoCAD LT
    Last Post: 6th Nov 2014, 06:59 pm
  2. Plot style table editor - Help
    By Faouweb in forum AutoCAD Drawing Management & Output
    Last Post: 5th Sep 2014, 07:44 pm
  3. Missing plot styles
    By Butch in forum AutoCAD Drawing Management & Output
    Last Post: 9th Dec 2013, 03:50 pm
  4. Open Plot Style Table Editor
    By FELIXJM in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Aug 2012, 12:10 am
Tags for this Thread
