Results 1 to 3 of 3
    Full Member
    TheyCallMeJohn's Computer Details
    Windows 7
    Dell Precision M6800
    Intel Core i7-4930MX @ 3.00 GHz
    32.0 GB
    NVIDIA Quadro FX 5800
    AutoCAD 2015
    Apr 2010
    Huntington Beach, CA
    80
    Default Modify an X, Y, X Point Using Math
    Hey Guys,
    Its been a awhile since I have done any Autolisp programming and I am stuck...
    I am using a conditional statement to generate a number i.e. 1.625 and then I want to add that to the Z elevation of a point but it keep erroring out at this line. I have spent about an hour and half looking back thru resources and haven't been able to find the correct syntax.
    This is the line erroring out:
    Code:
    (setq NEWPT1 (APPEND (LIST (CAR USRP1) (CADR USRP1)) (+ (CDDR USRP3) TRAP_Z_OFF))) ; ERRORS OUT HERE
    Here is the full code.
    Code:
    (defun C:droptrap()
    	(command "UNDO" "BEGIN")
    	(initerr)
    	(setvar "lunits" 2)
        (setvar "luprec" 4)
    	(setvar "attreq" 0)
    	(setq OLDCMD (GETVAR "CMDECHO"))
    	(setvar "CMDECHO" 0)
    	(setq OLDOSMODE (GETVAR "OSMODE"))
    	(setvar "OSMODE" 0)
    	(setq OLDORTHOMODE (GETVAR "ORTHOMODE"))
    	(vl-load-com)
    	(setq thisdrawing (vla-get-activedocument (vlax-get-acad-object)))
    	(initget "1 2 3 4")
    	(setq TRAP_TYPE (getkword "\n Select trapeze type: ([1]:1-5/8x1-5/8, [2]:1-5/8x1-5/8 B2B, [3]1-5/8x13/16, [4]1-5/8x13/16 B2B):  "))
    	(if (or (= TRAP_TYPE "1")(= TRAP_TYPE "3"))
    			(initget "1 2")
    			(setq FACE_DIR (getkword "\n Trapeze opening up or down?: ([1]:UP [2]:Down):  "))
    		(setq FACE_DIR "1")
    	(cond
    		((and (= TRAP_TYPE "1")(= FACE_DIR "2"))
    			(setq TRAP_Z_OFF 1.625))
    		((and (= TRAP_TYPE "3")(= FACE_DIR "2"))
    			(setq TRAP_Z_OFF 0.8125))
    		(T (setq TRAP_Z_OFF 0.0))
    	(setq blockname "TRAP-XDATA-T1_1.625")
    	(setq USRP1 (GETPOINT "\n Select center point of rod 1: "))
    	(setq USRP2 (GETPOINT "\n Select center point of rod 2: "))
    	(setq USRP3 (getpoint "\n Select elevation of attachment point: "))
    	(setq NEWPT2 (APPEND (LIST (CAR USRP2) (CADR USRP2)) (+ (CDDR USRP3) TRAP_Z_OFF))) ; ERRORS OUT HERE TOO
    	(setq MIDPT (POLAR NEWPT1 (ANGLE NEWPT1 NEWPT2) (* (DISTANCE NEWPT1 NEWPT2) 0.5)))
    	(setvar "ORTHOMODE" 1)
    	(COMMAND "-INSERT" BLOCKNAME MIDPT "1" "1" NEWPT2)
    	(command "rotate3d" (entlast) "" 2 NEWPT1 NEWPT2 90)
    	(setvar "OSMODE" OLDOSMODE)
    	(setvar "CMDECHO" OLDCMD)
    	(setvar "CLAYER" LAYNAME)
    	(COMMAND "UNDO" "END")
    (PRINC)
    The code is unfinished so I am trying to keep it working as I build it.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Without looking over all of your code:
    Code:
    (setq NEWPT1 (LIST (CAR USRP1) (CADR USRP1) (+ (CADDR USRP3) TRAP_Z_OFF)))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,595
    Like Lee spotted the missing "A" very quickly another way is you can use
    Code:
    (nth 0 pt); X
    (nth 1 pt); Y
    (nth 2 pt); Z
  1. All You Need is Math
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 13th Feb 2015, 04:50 pm
  2. modify point style or library
    By guigol in forum AutoCAD Beginners' Area
    Last Post: 2nd Oct 2012, 05:36 pm
  3. cad is like math
    By michaeloureiro in forum AutoCAD Drawing Management & Output
    Last Post: 18th Aug 2011, 12:02 am
  4. Want to modify a simple dimension suffix modify visuallisp
    By CADkitt in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Sep 2010, 01:52 pm
  5. Block insertion point modify?
    By manirpg in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2010, 06:51 pm
Tags for this Thread
