Type B or BLOCK in the command line to create a Block within the drawing (which will make it all one entity), and use W or WBLOCK to export/save it (only if needed).
Type DIMASSOC in the command line and set it to 2 to make the dimensions move/change with changes.
EDIT: i just saw you're using LT 2007, i'm sure these commands are the same as all the others, but just in case post up.
