vernonlee Posted April 15, 2015 Share Posted April 15, 2015 (edited) Hi. I have an assignment involving around 200 drawings. Any LISP or Scripts that I can use to update a text attribute value. They all have the same tag name & value to it. They are within a attribute block with many other text attributes, but i only need to change the value for one of the tag which is DATE. Block name: Title_Block Tag name : DATE Value: APR 2015 Thanks Edited April 15, 2015 by vernonlee Quote Link to comment Share on other sites More sharing options...
jonathann3891 Posted April 15, 2015 Share Posted April 15, 2015 I believe Lee Mac's Global Attribute Extractor & Editor will do the trick. http://www.lee-mac.com/macatt.html Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 15, 2015 Share Posted April 15, 2015 Thanks for the recommendation Jonathann Alternatively, my Batch Attribute Editor may help. Lee Quote Link to comment Share on other sites More sharing options...
vernonlee Posted April 16, 2015 Author Share Posted April 16, 2015 Thanks guys. Tried Lee Mac's Global Attribute Extractor & Editor & it works. Actually many months ago i also was testing that LISP but failed to get it to work. Now it seems fine. Thanks Lee Quote Link to comment Share on other sites More sharing options...
vernonlee Posted April 16, 2015 Author Share Posted April 16, 2015 (edited) I was using Global Attribute Extractor & Editor. It will stop at certain files & I got this error. Any advise? Command: MACATTEDIT; error: Exception occurred: 0xC0000005 (Access Violation) ; warning: unwind skipped on unknown exception Command: I also tried those files that got errors & use Batch Attribute Editor instead but it got errors as well Edited April 16, 2015 by vernonlee Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 16, 2015 Share Posted April 16, 2015 It sounds like the problem lies with those particular drawing files - have you tried auditing the files? Quote Link to comment Share on other sites More sharing options...
vernonlee Posted April 16, 2015 Author Share Posted April 16, 2015 It sounds like the problem lies with those particular drawing files - have you tried auditing the files? Thanks Lee. Will try to audit the drawings. BTW, there are some files i discover that did not have the same block name hence the value was not changed. But the drawings was saved nevertheless. Is it possible to, if the drawings do not have that block name, either it will not save it or is there some kind of log that will list out which files have been not been updated? Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 16, 2015 Share Posted April 16, 2015 You might give -PURGE Regapps on those files. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 17, 2015 Share Posted April 17, 2015 Is it possible to, if the drawings do not have that block name, either it will not save it or is there some kind of log that will list out which files have been not been updated? Thank you for the suggestion - I'll look to implement something like this in the next release of the application. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted April 17, 2015 Author Share Posted April 17, 2015 Thank you for the suggestion - I'll look to implement something like this in the next release of the application. Thank for the consideration. Quote Link to comment Share on other sites More sharing options...
abra-CAD-abra Posted April 18, 2015 Share Posted April 18, 2015 vernonlee, In addition to Lee's application you may also like to consider this application. Both very good indeed. Cheers, Quote Link to comment Share on other sites More sharing options...
