+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Junior Member
    Using
    AutoCAD 2014
    Join Date
    Dec 2011
    Location
    Great Pacific Northwest - USA
    Posts
    19
    Default alert box question - layer change
    When I select some entities and send them to a layer that is off, frozen or both, I get an alert box that says "One or more objects has been moved to a frozen or turned off layer." That only happens when I send them off using the properties dialog box, when I send them off using the layers pulldown in the ribbon menu, I don't get this alert box. I prefer the second method only when I have a dwg with xrefs, because it won't list the huge list of xrefs, but I prefer the properties box because it does a lot more, but that alert box is annoying, can it be turned off?
    I'm using 2011 and am wondering if they have or will make the layers pulldown in the properties box filter out xref layers?
    Thanks!
    R.L. Hamm
  2. #2
    Forum Deity
    Computer Details
    nestly's Computer Details
    Operating System:
    Windows 7 Pro (64bit)
    Using
    AutoCAD 2015
    Join Date
    Sep 2010
    Location
    PA
    Posts
    3,444
    Default
    I believe the following to be correct in reference to the warning message above:
    1) There is no way to suppress the warning when sending an object to an OFF or Frozen layer via Properties Palette. (all versions 2011-2016)
    2) EXPERT sysvar (EXPERT=1) will suppress the warning when sending an object to an OFF or Frozen layer via Layers Toolbar (all versions 2011-2016)
    3) Sending an object to and OFF or Frozen Layer via the Ribbon Layer dropdown will not give the warning in 2011, but it will in 2012 thru 2016
    4) Beginning in 2014, Xref layers are not included in the Properties Layer dropdown list.
  3. #3
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    5,964
    Default
    Quote Originally Posted by nestly View Post
    Attachment 53843
    Nestly, that's quite a comprehensive assessment of the problem, nicely done.
    For those who may be unfamiliar with the EXPERT system variable, it is very helpful, especially so, as one becomes more proficient with the software, as described by the screeshot from the SYSVDLG command.
    Volume and repetition do not validate opinions forged in the absence of thought.
Similar Threads
  1. Selected insert block to different layer but will not change to that layer color 8 gr
    By cadmando2 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Jun 2014, 11:49 am
  2. lisp to change layer properties if layer name contains text
    By pnoraa in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Sep 2013, 11:58 am
  3. Tough Question - Layer Locking (Make Layer Visible But No Pick)
    By johnshar123xx in forum AutoCAD General
    Last Post: 21st Nov 2008, 03:20 pm
  4. Change Layer Prefixs and Layer Names
    By ML0940 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2008, 11:11 am
  5. Change layer and return to layer using button
    By Vigilante in forum AutoCAD General
    Last Post: 6th Sep 2007, 07:01 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
