Select Mpolygon if they have text inside.
subodh_gis
This code is selecting closed polylines if they have more than 1 text inside.
How can we do this with Mpolygon instead closed polylines.
(defun c:TE ( / app ent grp idx lst mni mxa out sel tmp txt )
(getvar "cmdecho")
(setvar "cmdecho" 0)
   (if (setq sel (ssget "_X" '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1) (8 . "TOPOLOGY"))))
           (repeat (setq idx (sslength sel))
               (setq ent (ssname sel (setq idx (1- idx)))
                     lst (cons (cons ent (mapcar 'cdr (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) (entget ent)))) lst)
           (setq tmp (apply 'append (mapcar 'cdr lst))
                 mni (car tmp)
                 mxa (car tmp)
           (foreach pnt (cdr tmp)
               (setq mni (mapcar 'min mni pnt)
                     mxa (mapcar 'max mxa pnt)
           (setq app (vlax-get-acad-object)
                 out (ssadd)
           (vla-zoomwindow app (vlax-3D-point mni) (vlax-3D-point mxa))
           (foreach grp lst
               (if
                   (and
                       (setq txt (ssget "_wp" (mapcar '(lambda ( p ) (trans p (car grp) 1)) (cdr grp)) '((0 . "TEXT,MTEXT")(8 . "TXT01_PARCEL"))))
                       (< 1 (sslength txt))
                   (ssadd (car grp) out)
              (setq txt nil)
               (gc)
           (sssetfirst nil out)
(vl-load-com) (princ)
