motee-z Posted April 19, 2015 Share Posted April 19, 2015 can any one guide me how to create solid between 2 3d polyline that represented a wall with different height and the bottom 3dpolyline not in one even thanks Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 20, 2015 Share Posted April 20, 2015 (edited) Are the 3D Polylines straight? Closed Polygons? Can you post what you have got so far, someone will be happy to help you if you do. Edited April 20, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
motee-z Posted April 20, 2015 Author Share Posted April 20, 2015 thank you for reply here is a sample 3d wall.dwg Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 20, 2015 Share Posted April 20, 2015 That is quite a can of worms vou've got there! I am having a hard time getting my head around it. I never use Surfaces, always model 3D Solids, but there are plenty of other forum members who WILL likely be able to help you as a Surface or maybe a Mesh. I will be curious to see how they suggest doing it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 20, 2015 Share Posted April 20, 2015 It would help to know what version of AutoCAD you are using. My initial thought would be to create a 2D profile of the bottom and top of the wall then use the LOFT command. You might have to use the Guides option. I can't say for sure as your drawing appears to be missing some information. Quote Link to comment Share on other sites More sharing options...
motee-z Posted April 20, 2015 Author Share Posted April 20, 2015 i draw here surface just for illustration i want it solid if can be done Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 20, 2015 Share Posted April 20, 2015 The drawing was done using the default drawing template file (acad.dwt) which utilizes decimal inches. Was that your intent? I think I'll just pass this one by. Hope you get it figured out. Good luck. Quote Link to comment Share on other sites More sharing options...
motee-z Posted April 20, 2015 Author Share Posted April 20, 2015 i am using cad2013 and template you had mentioned and decimal metric units Quote Link to comment Share on other sites More sharing options...
lrm Posted April 20, 2015 Share Posted April 20, 2015 Select the surfaces and then use THICKEN to extrude them into a solid. You can then use UNION to join the individual solids into one solid object. Quote Link to comment Share on other sites More sharing options...
motee-z Posted April 20, 2015 Author Share Posted April 20, 2015 that,s great thank you irm Quote Link to comment Share on other sites More sharing options...
