Recreate hatch Boundary of Multiple hatches
nod684
hello CADTutor, i want to recreate the boundary of multiple hatches and the re-created boundary should adopt the correspondin layer of the hatches.
I tried using the HATCHGENERATEBOUNDARY command but it uses the current layer as the layer for the boundary for all the hatches
kindly see attached example file...
recreate hatch boundary.dwg
Use a different program rather than the inbuilt command like hatchB.lsp you could edit it to use hatch object layer.
;;; HATCHB.LSP ver 2.1
;;; Recreates hatch boundary by selecting a hatch
;;; Boundary is created in current layer/color/linetype in WCS
;;; Known problem with some elipses and splines
;;; By Jimmy Bergmark
;;; Copyright © 1997-2004 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com
Thanks Bigal, i have tried this also but this one also uses the current layer as a boundary..
;;; HATCHB.LSP ver 2.5
;;; Copyright (C) 1997-2008 JTB World, All Rights Reserved
;;; Website: [url="http://www.jtbworld.com"]www.jtbworld.com[/url]
;;; E-mail: [email="info@jtbworld.com"]info@jtbworld.com[/email]
;;; 2000-02-12 - First release
;;; 2000-03-27 - Counterclockwise arc's and ellipse's fixed
;;;              Objects created joined to lwpolyline if possible
;;;              Error-handling, undo of command
;;;              Can handle PLINETYPE = 0,1,2
;;; 2000-03-30 - Integrating hatchb and hatchb14
;;;              Selection of many hatches
;;;              Splines supported if closed.
;;; 2001-04-02 - Fixed bug with entmake of line with no Z for r14
;;; 2001-07-31 - Removed an irritating semicolon to enable polylines to be created.
;;; 2001-10-04 - Changed mail and homepage so it's easy to find when new versions comes up.
;;; 2003-02-06 - Minor fix
;;; 2003-02-17 - Area returned if no islands is found since it's not consistant
;;; 2003-05-19 - Fix to take PEDITACCEPT variable used in AutoCAD 2004 into account
;;; 2004-11-05 - Minor bugs fixed
;;; 2006-03-18 - Nothing changed from 2.1 other that it's been confirmed to work with AutoCAD 2007
[b];;; 2006-05-13 - Create the boundary on the same layer as the hatch using the hbl command [/b] and
;;;              on current layer/color/linetype using the hb or hatchb command
;;; 2007-02-08 - Fixed a bug with the hbl command
;;; 2008-02-29 - Support for hatches in non WCS thanks to xiaocai
;;; Tested on AutoCAD r14, 2000, 2000i, 2002, 2004, 2005, 2006, 2007, 2008, 2009
Problem solved. i wasn't reading!
my bad!
the hbl command
nod684,
Try the attached - I sympathize entirely with your IT pain!
[ATTACH]53912[/ATTACH]
Cheers,
Thanks a lot its working!
  • 5 years later...
Having trouble with the attached BulkRHB.lsp
Using in 2019.  GO through commands and in the end says objects are not in the current space.
Thanks,
SS
For hatches not associated with a boundary this will recreate the boundary segments on the hatches layer but requires Express Tools installed.
;;; ReAssHatch.lsp requires Hatchutil.lsp which came with Express Tools.
;;; Add boundaries & reassociate them to a selection of Hatch entities.
;;; by: Tom Beauford
;;; BeaufordT@LeonCountyFL.gov
;;; LEON COUNTY PUBLIC WORKS ENGINEERING SECTION
(defun c:ReAssHatch ( / ss e# ent)
  (setq ss (ssget '((0 . "HATCH")(71 . 0)))
        e# (sslength ss)
  (if(not acet-hatch-remake)(load "Hatchutil"))
  (repeat e#
    (setq e# (- e# 1))
    (acet-hatch-remake (ssname ss e#))
    (entdel (ssname ss e#))
