Results 1 to 5 of 5
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Default Change colors viewport automatically after using lisp
    Hello everybody!
    I have a lisp file which creates 2 new commands. If I use tne first command, all the viewports in my drawing are locked. If I use the other command, they are all unlocked again.
    If I use these commands, also the colors of these viewports are changing. If I lock them, they become green. If I unlock the viewports, they become red. The colors are only changing after I use these created commands.
    If I want to change something and I need to unlock a (locked=green colored) viewport manually at the properties. The color of this viewport doesn't change into red.
    Is there a way to change this lisp, so the color of a viewport is also changing after I lock or unlock him manually?
    This is the lisp:
    Code:
    (vl-load-com)
    (defun dxf (n ed) (cdr (assoc n ed)))
    (defun c:vpl (/ AD COUNT ENT I PL SS TABNAME VP VPNO)
        (setq ad (vla-get-activedocument (vlax-get-acad-object)))
        (vlax-for lay (vla-get-layouts ad)
            (if (/= (setq TabName (strcase (vla-get-name lay))) "MODEL") ;_ end of /=
                    (if (setq ss (ssget
                                     "X"
                                     (list (cons 0 "viewport")
                                     ) ;_ end of list
                                 ) ;_ end of ssget
                        ) ;_ end of setq
                            (setq count (sslength ss))
                            (setq i 0)
                            (if (> count 0)
                                    (while (< i count)
                                        (setq
                                            ent (ssname ss
                                                        i
                                                ) ;_ end of ssname
                                        ) ;_ end of setq
                                        (setq vpNo
                                                 (dxf
                                                     69
                                                     (entget
                                                         ent
                                                     ) ;_ end of entget
                                                 ) ;_ end of dxf
                                        ) ;_ end of setq
                                        (if (> vpNo 1)
                                                (setq vp (vlax-ename->vla-object
                                                             ent
                                                         ) ;_ end of vlax-ename->vla-object
                                                ) ;_ end of setq
                                                (if (= (vla-get-clipped
                                                           vp
                                                       ) ;_ end of vla-get-clipped
                                                       :vlax-false
                                                    ) ;_ end of =
                                                        (vla-put-color
                                                            vp
                                                            3
                                                        ) ;_ end of vla-put-color
                                                        (vla-put-layer
                                                            vp
                                                            "defpoints"
                                                        ) ;_ end of vla-put-layer
                                                    ) ;_ end of progn
                                                        (setq
                                                            pl (entget
        (dxf
        340
        (entget
        ent
        ) ;_ end of entget
        ) ;_ end of dxf
                                                               ) ;_ end of entget
                                                        ) ;_ end of setq
                                                        ;get clip entity
                                                        (setq pl (vlax-ename->vla-object
        (dxf -1
        pl
        ) ;_ end of dxf
                                                        ) ;_ end of setq
                                                        (vla-put-color
                                                            pl
                                                            3
                                                        (vla-put-layer
                                                            pl
                                                            "defpoints"
                                                        (vla-put-color
                                                            vp
                                                            3
                                                        (vla-put-layer
                                                            vp
                                                            "defpoints"
                                                    ) ;_ end of progn
                                                ) ;_ end of if
                                                (vla-put-displaylocked
                                                    vp
                                                    :vlax-true
                                                ) ;_ end of vla-put-displaylocked
                                                (vla-update vp)
                                            ) ;_ end of progn
                                        ) ;_ end of if
                                        (setq i (1+ i))
                                    ) ;_ end of while
                                ) ;_ end of progn
                            ) ;_ end of if
                        ) ;_ end of progn
                    ) ;_ end of if
                ) ;_ end of progn
            ) ;_ end of if
        ) ;_ end of vlax-for
    ) ;_ end of defun
    (defun c:vpu (/ AD COUNT ENT I PL SS TABNAME VP VPNO)
                    (if (setq ss (ssget
                                     "X"
                                     ) ;_ end of list
                                 ) ;_ end of ssget
                        ) ;_ end of setq
                            (setq i 0)
                            (if (> count 0)
                                    (while (< i count)
                                        (setq
                                            ent (ssname ss
                                                        i
                                                ) ;_ end of ssname
                                        ) ;_ end of setq
                                        (setq vpNo
                                                 (dxf
                                                     69
                                                     (entget
                                                         ent
                                                     ) ;_ end of entget
                                                 ) ;_ end of dxf
                                        ) ;_ end of setq
                                        (if (> vpNo 1)
                                                             ent
                                                ) ;_ end of setq
                                                           vp
                                                       :vlax-false
                                                    ) ;_ end of =
                                                        (vla-put-color
                                                            vp
                                                            1
                                            ; 3 green
                                                        (vla-put-layer
                                                            vp
                                                            "defpoints"
                                                    ) ;_ end of progn
                                                        (setq
                                                            pl (entget
        (dxf
        340
        (entget
        ent
        ) ;_ end of entget
        ) ;_ end of dxf
                                                               ) ;_ end of entget
                                                        ) ;_ end of setq
                                                        ;get clip entity
        (dxf -1
        pl
        ) ;_ end of dxf
                                                        ) ;_ end of setq
                                                        (vla-put-color
                                                            pl
                                                            1
                                                        (vla-put-layer
                                                            pl
                                                            "defpoints"
                                                        (vla-put-color
                                                            vp
                                                            1
                                            ; 3 green
                                                        (vla-put-layer
                                                            vp
                                                            "defpoints"
                                                    ) ;_ end of progn
                                                ) ;_ end of if
                                                    vp
                                                    :vlax-false
                                                (vla-update vp)
                                            ) ;_ end of progn
                                        ) ;_ end of if
                                        (setq i (1+ i))
                                    ) ;_ end of while
                                ) ;_ end of progn
                            ) ;_ end of if
                        ) ;_ end of progn
                    ) ;_ end of if
                ) ;_ end of progn
            ) ;_ end of if
    Is it also possible, after I opened a drawing, every viewport is locked (and green) already?
    In other words, the command "VPL" is already used before I can change the drawing?
    Thank you all for your replies!
    Greetings Sander
    Full Member
    Architectural
    Hsanon's Discipline Details
    Architect
    Architectural
    AutoCAD 2013
    Nov 2014
    93
    the concept is interesting .....
    Is it possible to colour code just the selected viewports ????
    i.e. there could be some red and some green viewports (unlocked and locked)
    you may wish to unlock just one viewport and let the rest be locked ???
    thanks
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Hello Hsanon,
    That's exactly what I want.
    If I use my command "VPL", every viewport becomes green and are locked.
    If I unlock one viewport instead of all the viewports, the color of this viewport is still green.
    I want every unlocked viewport visible in a red color. So I can see in the blink of an eye which are locked or unlocked.
    Super Member Commandobill's Avatar
    AutoCAD 2014
    Oct 2008
    Raleigh, NC
    538
    You could probably do it using a reactor. I'm not well versed in them, but I'm pretty sure it's possible.
    ***Commandobill***
    Abusing AutoCad Since 1999
    "Caddatude... Do you has it?"
    Sorry for my poor English, I'm American...
  5. #5
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Quote Originally Posted by Commandobill View Post
    I didn't work with a reactor since I am using AutoCad. I do not know what it is or how they work...
  1. Pick Viewport To Change All Colors To 253 Including Xrefs And Blocks.
    By caxtin in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jan 2018, 08:52 am
  2. LISP Routine to Change ALL 'GREEN' layer colors to '104'! HELP!
    By tmelancon in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Oct 2013, 07:25 pm
  3. Need LISP to change Layer Colors
    By bjpknox in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Jan 2009, 07:29 pm
  4. lisp or macro to change viewport colors
    By rami_9630 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jul 2008, 02:37 pm
  5. LISP or VBA to change all inserted block colors
    By vegasbuddhist in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Sep 2006, 10:26 pm
Tags for this Thread
