Results 1 to 7 of 7
    Full Member vasqrainier's Avatar
    not applicable
    Sep 2006
    63
    Unhappy how to make animation??
    i know now to move the around the carera of 3d Max...then how to view my camera result... its kind the hard... pls help...
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    1TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    What version on Max are you using and a little more info on what you would like to do would help aswell.
    USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
    If in doubt scale and don't ask!
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,641
    Check out www.the-area.com autodesk supersite for 3ds.
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
    not applicable
    Sep 2006
    63
    max 8.. how to preview and save? when i use the camera.. it hard to view it...
  5. #5
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    So you have the camera, the animation is set up properly and you wish a movie file you can play outside of 3D Max, right?
    The process is called RENDER. I use 3d MAX 7 but for sure the way is the same. So start the render dialog (my icon is like a tea pot near a window). A lot of settings are availabel but the most importants are:
    The time segment to render -be sure it is not set to render a single frame.
    The output file -must be able to record animation, so set it to AVI, not to BMP
    The vievport to render. Choose Camera01 or so from the pull-down menu.
    The rendering is usualy time consuming so it is preferable to render a few frames first and only if you like the results render the whole length.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  6. #6
    not applicable
    Sep 2006
    63
    the view is still the same... its still isometric view... why i will not move... i want the view of the camera capture...to move....my camera is moving then the view still thesame... i follow you procedure then the view is still thesame... why???
  7. #7
    Forum Newbie
    Architectural DT 2008
    Aug 2007
    Glasgow, Scotland
    4
    I know this is a bit late, but... you want to make sure your view is set to the camera. If you're looking at the plan view or something, that's what will render. Default location is the active view (this being the one with the red or yellow frame)
  1. animation
    By Rick Fleischer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Jun 2005, 08:51 pm
  2. animation, auto cad ( 2002 )
    By Stan in forum AutoCAD General
    Last Post: 28th Mar 2005, 10:29 pm
  3. New to 3d Modeling/rendering/animation
    By jeepinaround in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th May 2004, 12:50 pm
  4. New Animation Tutorial
    By CADTutor in forum Design Software
    Last Post: 9th Oct 2002, 01:40 pm
