Surface area of a pipe using AutoCAD?
qiao
I have a frustum with 2 ends having different diameters and I need to open the frustum, flatten it and then measure the total surface area in AutoCad. I know the formula for calculating area and stuff, but I have no idea how exactly to draw the flattened frustum with all the dimensions given. i have both diameter... show more
Update: And again I am not looking for any mathematical formulas to find out area, I just want to know how to do it in AutoCAD as I am just a beginner in AutoCAD.
Welcome to CADTutor. :)
Unfortunately Autocad does not have any special functions nor tools for dealing with such unfolding or unfurling of pipe like shapes.
Inventor does have such tools though.
Possibly the free FUSION 360 (I think that is what they call it now), from Autodesk MAY have such capability, not sure.
Be patient, and no doubt somebody will have a suggestion for how to handle this, but it won't be automagically done by Autocad vanilla.
It just occurred to me that if you model it as a SURFACE, instead of a solid, that might be the way to go, but I never use Surfaces, so not sure.
This may be a way but you do need one calc draw your side view etc extend to vanishing pt draw a arc with rad of total side length dont worry about its correct length for moment, the length of the arc must be PI * diameter yes get you calculator or "cal pi * linelength * 2.0. Ok using Lengthen you can stretch the arc length to correct required Pi*d length add inner arc etc and hatch this will give you area. Lengthen T length pick arc.
Dagdad is right. AutoCAD doesn't do this automagically but this attached lisp file will. Save it where you can find it, open autocad, type appload, in the dialog find this file, select it and then, click "load". Then, type CNN + Enter and follow the prompts. You can also search this forum for "how to work with lisp files"
cone.lsp
