import Multiples Dgn's to single Dwg
rk25134
Please suggest how to change the code accordingly
(VL-LOAD-COM)
(defun C:D2D (/path dgnfile SDI_Mode)
(setq path
((setq DirPath (acet-ui-pickdir))
(setq ref (vlax-get-acad-object))
(SETQ FILES (VLA-GET-FILES
(VLA-GET-PREFERENCES ref)))
(SETQ OLDSUPPORT (VLA-GET-SUPPORTPATH FILES))
(SETQ NEWPATH (STRCAT OLDSUPPORT ";" DirPath ";"))
(VLA-PUT-SUPPORTPATH FILES NEWPATH));;Default path for DGN files location.
DGNIMPORTMODE 0 ;;Imports the DGN file in a new drawing file.
SDI_Mode SDI ;;Save Current SDI MODE
SDI 1 ;;SET Single Drawing Mode for AutoCAD.
(setq files (vl-directory-files path "*.dgn"))
(foreach dgnfile files
(command "-dgnimport" (strcat path dgnfile) "" "" "" "y" (strcat path dgnfile ".dwg"))
Adjusted but not tested
(VL-LOAD-COM)
(defun C:2D (/path dgnfile SDI_Mode)
(setq path (setq DirPath (acet-ui-pickdir)))
(SETQ FILES (VLA-GET-FILES (VLA-GET-PREFERENCES ref)))
(VLA-PUT-SUPPORTPATH FILES NEWPATH);;Default path for DGN files location.
(setvar "DGNIMPORTMODE" 0) ;;Imports the DGN file in a new drawing file.
(setq SDI (getvar "SDI_Mode"))  ;;Save Current SDI MODE
(setvar "SDI_mode"  1) ;;SET Single Drawing Mode for AutoCAD.
) ; foreach
) ; defun
