samifox Posted April 24, 2015 Share Posted April 24, 2015 Helo my friends! Its been a while since i post happy to be back. Im loiking for a way to export my cuix to indented text list. Ive tried to browse the xml but there where to much unneeded data. I need only the names . Why i need it? I want to document my costumization. Doing it one by one might take me several years. Thanks Sami ACad 10 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 25, 2015 Share Posted April 25, 2015 1st thing make a copy of your cuix rename to .zip and open save all to a new directory. Use cui to mnu.vlx this converts the cui to a mnu in the example below Surfal.cuix the only cui I needed to convert was popmenu.cui you may need to do all as my menu was a partial to start with. I have attached the original surfal.mnu the renamed surfal.zip and then the converted popmenu.mnu so you can compare to original. You will still need to edit it a bit buts its close. I renamed a couple by adding txt to upload. Next time will zip surfal.mnu.txt surfal.zip PopMenuRoot.cui.mnu.txt CUI to MNU.zip Quote Link to comment Share on other sites More sharing options...
