Joints
Jake8090
Can anyone advise please.
I have modelled a wind mill set on a shaft in turn set into a ball bearing. I would like use a joint to show rotation of the blades in a simulation. could anyone advise which joint could be used and where it would be placed.I have been trying for several hours without success (All part of learning curve).Many thanks
Jake8090
Thank you Lazer
Would have added file to post but not sure how to do this. Could you advise please.
JD did help over 12 months ago now but unfortunately as you get older (76) it does not stick like it used to.
