Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Junior Member
    AutoCAD 2014
    Mar 2015
    10
    Default Object Order, Display Order, Transparency?
    I am trying to assemble a few components. I'm drawing on a 2D Wireframe, and mounting some components on top of rails. See picture below
    Now, the red crossbars are at the back, with the white rails on top of them. The electrical blocks (blue w/ yellow text and red wiring) should be mounted on the (white) rails.
    I want to hide the rail sections that are behind the electrical blocks, and hide all the crossbars that are behind a block or a rail. How do I do this? Ordering? Transparency? I have everything in different Layers currently, but I can change the Layering however I like
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    There is a command for display order. It is easily accessed from the right click shortcut menu.
    Have you tried that and it's not working?
    Drafting is a breeze.
    Junior Member
    AutoCAD 2014
    Mar 2015
    10
    RobDraw,
    Looks like I had the right-click menu disabled (somehow) in Prefs. I re-enabled it, now I see a "Draw Order", and I can send the rails and crossbars to the back, but they're still visible behind the other stuff.
    Can I set them to be completely opaque even though technically they're only wireframes?
    I'm using AutoCAD Mechanical 2014.
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Applying the AutoCAD term "wireframe" to a 2D drawing can be confusing. The view style setting has no affect on 2D drawings.
    If I understand you correctly, here are two ways to accomplish this:
    Trim the lines - recommended
    Use wipeouts - not recommended but can be done
    I thought the command was "Display Order".
  5. #5
    AutoCAD 2013
    Nov 2011
    5,995
    Quote Originally Posted by RobDraw View Post
    I would probably just TRIM them too.
    Display Order sounds more like how we use it, but in Autocad Vanilla the command is DrawOrder.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by Dadgad View Post
    Dam, bitten by that MEP bug again, but I agree, Draw Order doesn't describe it very accurately. It's actually a throw back command from the days of pen plotters. The objects would actually be drawn in the assigned order. Watching those plotters was quite mesmerizing.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    If you do not want them visible then freeze or turn off the layers they are on, if you want them faded, then increase the transparency of the layer.
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by SLW210 View Post
    and how does that help with having the desired part of the linework display as is?
  9. #9
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    He said it was on separate layers, I wouldn't recommend trimming unless as a last resort.
    For that he needs to use a solid hatch, there is also a LISP by Lee Mac, break blocks that will trim it, but I would use that as a last resort.
    This is the second time you have tried to start something today, I'm getting tired of it.
  10. #10
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You misinterpreted the other post. I explained that. Your problem, not mine.
    This time, your solution did not solve the OPs situation. I questioned it. Problem?
    BTW, trimming is a perfectly acceptable way of doing this. It is not a last resort for me.
    If I had said SLW, you idiot, that doesn't solve the problem, then I would be starting something.
    Start something? Not. I'm tired of you being so sensitive.
  1. Display Order
    By Marc5 in forum AutoCAD General
    Last Post: 7th Jul 2011, 01:52 pm
  2. display order
    By dirtlegg in forum Civil 3D & LDD
    Last Post: 23rd Dec 2010, 03:31 pm
  3. Question about object display order/fills compared to Vectorworks.
    By CalypsoArt in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Oct 2010, 07:45 pm
  4. display order help
    By kaya in forum AutoCAD General
    Last Post: 2nd May 2006, 09:42 pm
Tags for this Thread
