Kevin Malone Posted April 30, 2015 Share Posted April 30, 2015 (edited) Hello, I have trying to create this linetype for couple of days with no success. If anyone can help me it would save me great amount of time. So the line should have dots on both ends, and line segment should be continuous. http://prntscr.com/6zuv5u Thank you Edited May 8, 2015 by Kevin Malone Quote Link to comment Share on other sites More sharing options...
tombu Posted May 7, 2015 Share Posted May 7, 2015 Not sure what you tried to attach, but a linetype will place the dots at intervals, not at endpoints. It could be done with lisp. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 7, 2015 Share Posted May 7, 2015 Post an image of what you are trying to replicate and attach a copy of your line definition file as it exists so far. Maybe it is possible using the MKSHAPE and MKLTYPE commands. Quote Link to comment Share on other sites More sharing options...
tombu Posted May 7, 2015 Share Posted May 7, 2015 This requires AutoCAD's Swiss Light text style, but most TrueType fonts should support the Unicode dot. *DotLine,Dot Line •---------• S,.01,["\U+2022",Swiss Light,S=.1,R=0,X=-.05,Y=-.0515],1 May get you started, but I still don't think you're going to get what you're asking for from a linetype. Quote Link to comment Share on other sites More sharing options...
Kevin Malone Posted May 8, 2015 Author Share Posted May 8, 2015 Sorry for late reply, I was abroad. I have edited first post, now you can see what I'm trying to do. Again, this is how I need my line to look like . __________________ . So, it has a dots in the endpoints, constant space between dot and line, and line segment is continuous line. No matter if line is 10, 100 or 1000 units long, it should always have dots in endpoints, and line in between. Quote Link to comment Share on other sites More sharing options...
tombu Posted May 8, 2015 Share Posted May 8, 2015 I got that from your first message, a linetype will place the dots at intervals, not at endpoints. It could be done with lisp, but not with a linetype. The linetype I posted above is probably as close as you're going to get. Quote Link to comment Share on other sites More sharing options...
Kevin Malone Posted May 13, 2015 Author Share Posted May 13, 2015 OK. Thank you LISP doesn't help me much. I already have a module (as part of module package for Surveying), where I can create this type of line, but it doesn't stay that way (as soon as I reopen drawing, copy or move even one line, everything goes back as it was), plus to create it I have to set node in every vertex. All of this was fine when I had a couple parcels (polygons) to work with. But lately it's near 2-3 hundreds, and getting more and more every month. So, switching linetype for all lines would be most simple and elegant solution. Again, thank all of you for your time. Now, at least I know it's not possible Quote Link to comment Share on other sites More sharing options...
tombu Posted May 13, 2015 Share Posted May 13, 2015 OK. Thank you LISP doesn't help me much. I already have a module (as part of module package for Surveying), where I can create this type of line, but it doesn't stay that way (as soon as I reopen drawing, copy or move even one line, everything goes back as it was), plus to create it I have to set node in every vertex. All of this was fine when I had a couple parcels (polygons) to work with. But lately it's near 2-3 hundreds, and getting more and more every month. So, switching linetype for all lines would be most simple and elegant solution. Again, thank all of you for your time. Now, at least I know it's not possible As a licensed surveyor (started in 1975) currently using Civil 3D standard pratice is blocks with annotation for monuments or calculated points at corners. What type of software are you using to do this? i've used Eagle Point in the past and have worked with surveyors who used Carlson. Quote Link to comment Share on other sites More sharing options...
