CadFrank Posted May 7, 2015 Share Posted May 7, 2015 Hi, I would like to know is their's a way of putting text size relative to screen Thank ! Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 7, 2015 Share Posted May 7, 2015 Not that I am aware of. Why? Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 7, 2015 Share Posted May 7, 2015 Which screen? Modelspace, paperspace, or viewport. Those are the only choices, but the answer is yes. Set up an annotative text style, at the height you want it to appear on whichever view (screen) you wish, turn on Automatic Annotative scale adding, then no matter which of the above three you view the text in, it will appear the same size relative to the current view scale. The text will also print at the very same size. Annotative text will scale itself to the correct height based on the scale of the current view. However, in modelspace the text height will show at whatever annotative view scale you pick for it. (Not the same as scaling in modelspace.) This means, if you created the text to appear at 1/8" high in your viewports, (paper) and you set your modelspace annotative view scale to 1:1, your text will be actually 1/8" tall in modelspace. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 8, 2015 Share Posted May 8, 2015 Which screen? I took screen to mean the OPs monitor. Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 9, 2015 Share Posted May 9, 2015 I took screen to mean the OPs monitor.Yep, me too. After all, that would be the one they'ed be viewing the text with. But, if that were all there was to it, the answer would be "Zoom Wheel". Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 10, 2015 Share Posted May 10, 2015 This is a case of a poorly worded question. I think the question reads as the OP wanting text on the "screen" to adjust as he is zooming, i.e. text that is x number of pixels on the "screen" will stay x pixels no matter the zoom level. I cannot see anything but a mess being created out of that, so you probably are answering what he really is trying to ask. The world may never know... Quote Link to comment Share on other sites More sharing options...
Murph_map Posted May 10, 2015 Share Posted May 10, 2015 Possible with Autocad Map3d using Data Connect and labels, but yes it can be a mess if you don't know the math. Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 10, 2015 Share Posted May 10, 2015 The world may never know...Maybe the OP can't check in from home. We could find out more Monday. If doable, I have a co-worker who deserves a prank that would make his text stay the same screen size no matter what the zoom level is. Maybe there is a way to lock it to a certain physical pixel count or just have it not scale with zooming, like modelspace lineweight display is, via lisp. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 11, 2015 Share Posted May 11, 2015 Possible with Autocad Map3d using Data Connect and labels, but yes it can be a mess if you don't know the math. I came here to say this^^^^, but of course the Murph was already on the ball with it.. :-) Quote Link to comment Share on other sites More sharing options...
Murph_map Posted May 11, 2015 Share Posted May 11, 2015 I came here to say this^^^^, but of course the Murph was already on the ball with it.. :-) No football or NASCAR on TV so had to surf the forums. Quote Link to comment Share on other sites More sharing options...
Costinbos77 Posted October 6, 2016 Share Posted October 6, 2016 I solved this very simple : (vla-Put-Height yourText (* (getVar "viewSize") 0.03) ) and it's working very fine ! Quote Link to comment Share on other sites More sharing options...
