Copy Paperspace Tabs into new drawing paperspace tabs
Guitte
Hi,
Is it possible to copy paperspace tabs into a new drawing, without using "Save as" as an option?
Kind Regards,
Guitte
No, but you can import layouts.
My images came in out of order.
Right click on the layout tab or preview window and select "From Template".
Make sure file type is set to .dwg.
Browse to file and open it.
Select the layouts that you want and click on OK..
Yes you can. Go to one of your tabs in the new drawing (not the model tab) right click and select (from template) then browse to find the drawing that you want import your tabs from and select the tabs you want. That's all there is to it.
Thanks RobDraw, your awesome! Sit for almost an hour figuring, searching and trying.
Thanks once more.
