Guest Posted May 10, 2015 Share Posted May 10, 2015 Hi .I want to ask somethins. I want to run two commands the same time from mnu file example [set Paths ]^c^c_setpaths I am working Autocad2014 and have secure alerts .So i need before run the _setpaths to run _secureload 0 I don't know how to write it [set Paths ]^c^c_ secureload 0 setpaths [Example]^c^c_(command1) (command2) Any ideas ? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted May 10, 2015 Share Posted May 10, 2015 Is it possible to do this? Thanks Quote Link to comment Share on other sites More sharing options...
tombu Posted May 11, 2015 Share Posted May 11, 2015 Assuming you trust it why not just put setpaths code in a trusted folder? Malicious Code is out there, disabling the added protection AutoCAD provides doesn't make any sense. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 11, 2015 Share Posted May 11, 2015 Thanks i write it like this [set Paths ]^c^c_ secureload 0 setpaths and work !!! Quote Link to comment Share on other sites More sharing options...
