MillerMG Posted May 13, 2015 Share Posted May 13, 2015 Hello All, Does anyone else have an issue with the command LAYUNISO? Every now and then when using this helpful command after using LAYISO it says that "Layers isolate by LAYISO command have been restored" but that is not always the case. Sometimes the layers are not restored and are left in a frozen state. To get the layers back on a LAYTHW or an UNDO is neccessary to get them back. This is counter productive because this adds extra work. Any layers previously frozen are turned back on or if you use the UNDO you have to redo the work. Any ideas? Thanks in advance. Miller Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 13, 2015 Share Posted May 13, 2015 (edited) I have had that problem a few times in Autocad 2013 vanilla, and yes it is pretty annoying when it happens. I haven't really figured out WHY it happens, but wish that it didn't do it, even occasionally, as I love using LAYISO. For me UNDO is not an option, I will just use the Lighning Bolt if I need to THAW ALL, or if they are set to lock in LAYISO, then unlock them all at once as shown in the layer manager screenshot. Edited May 13, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
MillerMG Posted May 21, 2015 Author Share Posted May 21, 2015 Dadgad, I must say that yet again, I am very thankful for your post and insight into this matter. I knew that I would get a direct fix answer but another option. You have enlightened me! Much thanks! Miller Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 22, 2015 Share Posted May 22, 2015 I've had that happen in 2015 LT too, and I don't know why either. I usually just open the layer manager and shift/select bunches of layers at a time till I get the right ones back on, but I don't normally have more than a screen full of layers to deal with. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 22, 2015 Share Posted May 22, 2015 Me Too but usually when in a layout model view, in modelspace generally not a problem. Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 22, 2015 Share Posted May 22, 2015 Yep, layout model view and the layer manager on at the same time, eat up a lot of computer brain power. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 23, 2015 Share Posted May 23, 2015 Dadgad, I must say that yet again, I am very thankful for your post and insight into this matter. I knew that I would get a direct fix answer but another option. You have enlightened me! Much thanks! Miller You're very welcome, glad I could help. Quote Link to comment Share on other sites More sharing options...
MillerMG Posted July 7, 2015 Author Share Posted July 7, 2015 This is just an update to something I tried out. I set up some quick commands for LAYISO. CTRL + Right-Click Runs LAYISO and CTRL + SHIFT + Right-Click Runs LAYUNISO and I have not had it mess up even once so far over the past few weeks that I use it. Obviously I know that others already have commands set up on those keys. Just wanted to share. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 7, 2015 Share Posted July 7, 2015 Thanks for sharing, glad to hear you have tamed the beast. Quote Link to comment Share on other sites More sharing options...
