ohyahta Posted May 14, 2015 Share Posted May 14, 2015 Hi, I normally get "closed surface" iges file or step file. (see attached) Both are same model, but different format. I just don't know which is better format. I'd like to convert closed-surface model to solid model, Would you let me know how to? (I'v tried with iges file using surf-sculpt, but it says it is not watertight model If so, How can I close the gap?) and after converting, how can I check the model type (surface? or solid?) I am using AutoCAD 2013 student version. Thank you! Test2.zip Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 14, 2015 Share Posted May 14, 2015 I can convert it to several separate solids but I can't union it because there are inconsistencies in the geometry which are quite evident if one zooms in for a closer look at the various sections. Why not redraw it in AutoCAD since it really just appears to be an extruded circle? Quote Link to comment Share on other sites More sharing options...
ohyahta Posted May 14, 2015 Author Share Posted May 14, 2015 Would you please please try with this file again? newsurf.zip If this doesn't work, I will try re-model in Auto cad. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 15, 2015 Share Posted May 15, 2015 Unfortunately I can't do it at this time as I am not on my CAD computer. Perhaps someone else might be able to assist you. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 16, 2015 Share Posted May 16, 2015 I tried using CONVTOSOLID and also SURFSCULPT. Both operations failed. As ReMark mentioned, there are some obvious errors with your geometry. Switch to Conceptual Display and zoom in on the ends of the tube. You need to fix these problems or redraw by extruding a circle along a Polyline path. Personally, I think redrawing would be much easier and faster than trying to fix the problem. Quote Link to comment Share on other sites More sharing options...
