rafaelrafa10 Posted May 17, 2015 Share Posted May 17, 2015 Hello . I need to make some slots in the following drawing: The problem is im not figuring out how can i do that. The purpose is to do something like this: If anyone has any suggestion I would be glab. Thanks a lot Quote Link to comment Share on other sites More sharing options...
gbradley Posted May 18, 2015 Share Posted May 18, 2015 Quick Suggestion: Make your XZ plane Visible, Create a new Plane Tangent to Surface and parallel to Plane Make a new Sketch on this plane, and Extrude your First slot from there. Then do a Circular pattern. Quote Link to comment Share on other sites More sharing options...
Lazer Posted May 19, 2015 Share Posted May 19, 2015 Circular pattern is the best method to use. The slot looks to taper, not a problem add this when you cut the extrusion then circular pattern. Quote Link to comment Share on other sites More sharing options...
rafaelrafa10 Posted May 19, 2015 Author Share Posted May 19, 2015 thanks guys Quote Link to comment Share on other sites More sharing options...
