Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 76
    Full Member
    AutoCAD 2015
    May 2015
    39
    Angry CAN SOMEONE HELP ME CREATE THIS 3D image using viewports in AutoCAD?? PLEASE?
    can someone PLEASE help me make this using viewports?? its for my final tomorrow. i have to use three right viewport and it has to have those dimensions
    Senior Member
    ttray33y's Computer Details
    Windows 7
    Dell Precision T3500
    XEON W3503
    16GB
    Quadro 2000
    1TB
    Dell 21" LED (DUAL)
    P&ID
    ttray33y's Discipline Details
    Process & Instrumentation Designer
    P&ID
    Design and check process diagram for consistency in accordance to PIP and company standard
    P&ID 2014
    Jun 2013
    Inside my head.
    123
    ohh.. assignment/homework?
    AutoCAD 2013
    Nov 2011
    5,994
    Welcome to CADTutor.
    I suggest you 3D Model it, then let the program draw it for you using the VIEWBASE command.
    Start by drawing the right triangle with legs of lengths 3 & 6, as shown.
    You could just turn on your ORTHO, and draw a POLYLINE of length 6, then move your mouse to the left and click 3 ENTER, then C (for CLOSE) to Close the polyline forming the defining external triangular shape of the top view.
    Then you will be well on your way, report back when you have done that.
    Full Member
    AutoCAD 2015
    May 2015
    39
    hello! thank you for answering. i have to use the view port three: right
    i have problems creating the top view so i can extrude it
  5. #5
    Full Member
    AutoCAD 2015
    May 2015
    39
    hello! im having trouble making the triangle on top view. the commands im using are
    POLYLINE
    start point: 0,0
    then i make the line be 7 in length bc thats the base and then the next point i put is 3<60 but i cant do the rest so it has a length of 6 and makes a right triangle
  6. #6
    AutoCAD 2013
    Nov 2011
    5,994
    9 + 36 = 45.
    What is the square root of 45?
    You are assuming that the keyway is centered in the face, which it is not.
    If you do it like I said it will be very easy.
    You don't need to enter coordinate points.
  7. #7
    Full Member
    AutoCAD 2015
    May 2015
    39
    ok but i have never used viewbase. y professor said i had to use the viewports.what do you mean by turning on ortho? i just cant make the triagnle have the right angles and lengths
  8. #8
    AutoCAD 2013
    Nov 2011
    5,994
    You are over thinking it. The triangle I drew took about 10 seconds, should have taken 2 or 3.
    If you don't know about ORTHO, hit F8, to turn it on, it will constrain lines drawn to be at right angles.
    Do NOT enter the length of the hypotenuse, just because you see a value displayed on my screenshot, use the CLOSE option in the POLYLINE command, as I suggested earlier.
  9. #9
    Full Member
    AutoCAD 2015
    May 2015
    39
    ok this has clearned things up a little bit. i was making the lines like 3 with a 60 degree andgle and then trying to make a 6 with a 90 degree angle instead of making it straight up. how can i make the hole?
  10. #10
    AutoCAD 2013
    Nov 2011
    5,994
    The keyway like slot starts 3 units from the vertex and is one unit wide, right?
  1. Create a Drawing - Viewports problem
    By gnusselt in forum Autodesk Inventor
    Last Post: 21st Sep 2011, 04:01 pm
  2. Replies: 0
    Last Post: 31st Aug 2010, 10:50 pm
  3. One Raster Image, multiple viewports
    By Brian_63 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2009, 10:24 pm
  4. Scaling Viewports, image rotation, images in paper space
    By Jaco in forum AutoCAD Beginners' Area
    Last Post: 15th Apr 2004, 10:13 am
  5. is it possible 4 me 2 create a 3D image of pooh n autocad
    By madaryl in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Jan 2004, 02:08 pm
Tags for this Thread
