frankenstein19 Posted May 19, 2015 Share Posted May 19, 2015 can someone PLEASE help me make this using viewports?? its for my final tomorrow. i have to use three right viewport and it has to have those dimensions Quote Link to comment Share on other sites More sharing options...
ttray33y Posted May 19, 2015 Share Posted May 19, 2015 ohh.. assignment/homework? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 Welcome to CADTutor. I suggest you 3D Model it, then let the program draw it for you using the VIEWBASE command. Start by drawing the right triangle with legs of lengths 3 & 6, as shown. You could just turn on your ORTHO, and draw a POLYLINE of length 6, then move your mouse to the left and click 3 ENTER, then C (for CLOSE) to Close the polyline forming the defining external triangular shape of the top view. Then you will be well on your way, report back when you have done that. Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 hello! thank you for answering. i have to use the view port three: right i have problems creating the top view so i can extrude it Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 hello! im having trouble making the triangle on top view. the commands im using are POLYLINE start point: 0,0 then i make the line be 7 in length bc thats the base and then the next point i put is 3 Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 (edited) 9 + 36 = 45. What is the square root of 45? You are assuming that the keyway is centered in the face, which it is not. If you do it like I said it will be very easy. You don't need to enter coordinate points. Edited May 19, 2015 by Dadgad Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 ok but i have never used viewbase. y professor said i had to use the viewports.what do you mean by turning on ortho? i just cant make the triagnle have the right angles and lengths Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 You are over thinking it. The triangle I drew took about 10 seconds, should have taken 2 or 3. If you don't know about ORTHO, hit F8, to turn it on, it will constrain lines drawn to be at right angles. Do NOT enter the length of the hypotenuse, just because you see a value displayed on my screenshot, use the CLOSE option in the POLYLINE command, as I suggested earlier. Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 ok this has clearned things up a little bit. i was making the lines like 3 with a 60 degree andgle and then trying to make a 6 with a 90 degree angle instead of making it straight up. how can i make the hole? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 The keyway like slot starts 3 units from the vertex and is one unit wide, right? Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 So i have to make a keyway and a circle??? ):::: i have the basic triangle down. what do you mean the slot starts from the vertext and is one unit wide? do you mean the keyway?ive only made keyways using offset. it starts at 3 and is one unit wide yes. im sorry im so dumb this is my first engineering class Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 Don't worry about the circle right now. The keyway when viewed from the top view will be rectangular in shape, and i unit in width, and a half unit in depth, right? Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 do you think i should do the keyway first or the circle? ive only done keyways with offset, would that work? when doing the circle, i go to the middle of the front view and i make the circle with a diameter of 2 or a radius of 4 and then i extrude it? will that make it hollow? also i noticed that the keyway doesn't go all the way back, how can i make that Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 its ok i have the triangle down Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 I appreciate that you are highly motivated at the moment, and trying to do this, which is good. If you would apply a similar amount of zeal to reading my posts and following my clues/instructions, we could both quickly get back to other things. I suggested you complete the top view, which will look like a right triangle with a rectangular notch (which I have dubbed the keyway) at a well defined point along the hypotenuse of the triangle. That notch will be positioned as shown in your first post, and will be 1 unit in width along the hypotenuse, and 1/2 unit deep, if you follow me? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 its ok i have the triangle down Does that mean that you have successfully located the notch along the hypotenuse? Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 im sorrrrrrrrrrrrry! im just very confused! youre telling me to do the keyway in the top view. how do i know where to start? do i go to the front view and make a line at 3.00 and draw it upward so i know where the keyway starts? yess i do follow you with the dimensions of the rectangular notch! Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 am i doing this right so far?? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2015 Share Posted May 19, 2015 im sorrrrrrrrrrrrry! im just very confused! youre telling me to do the keyway in the top view. how do i know where to start? do i go to the front view and make a line at 3.00 and draw it upward so i know where the keyway starts? yess i do follow you with the dimensions of the rectangular notch! No apology required. Just relax, breathe, everything is going to be okay. I now see that you have a nice representation of the overall shape in your modelspace. Are you showing us a 3D Solid object, or are those just lines or polylines? I am trying to get you to 3D Model it, instead of just drawing it. Quote Link to comment Share on other sites More sharing options...
frankenstein19 Posted May 19, 2015 Author Share Posted May 19, 2015 is the keyway ok? when i do the hi command i cant see the extrude on the keyway, like the depth of it. but then again when i di the extrude i just did it downward after i drew it on the top view. is that correct? Quote Link to comment Share on other sites More sharing options...
