Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 76
  1. #11
    Full Member
    AutoCAD 2015
    May 2015
    39
    So i have to make a keyway and a circle??? ):::: i have the basic triangle down. what do you mean the slot starts from the vertext and is one unit wide? do you mean the keyway?ive only made keyways using offset. it starts at 3 and is one unit wide yes. im sorry im so dumb this is my first engineering class
  2. #12
    AutoCAD 2013
    Nov 2011
    6,056
    Don't worry about the circle right now.
    The keyway when viewed from the top view will be rectangular in shape, and i unit in width, and a half unit in depth, right?
  3. #13
    Full Member
    AutoCAD 2015
    May 2015
    39
    do you think i should do the keyway first or the circle? ive only done keyways with offset, would that work? when doing the circle, i go to the middle of the front view and i make the circle with a diameter of 2 or a radius of 4 and then i extrude it? will that make it hollow? also i noticed that the keyway doesn't go all the way back, how can i make that
  4. #14
    Full Member
    AutoCAD 2015
    May 2015
    39
    its ok i have the triangle down
  5. #15
    AutoCAD 2013
    Nov 2011
    6,056
    I appreciate that you are highly motivated at the moment, and trying to do this, which is good.
    If you would apply a similar amount of zeal to reading my posts and following my clues/instructions, we could both quickly get back to other things.
    I suggested you complete the top view, which will look like a right triangle with a rectangular notch (which I have dubbed the keyway) at a well defined point along the hypotenuse of the triangle. That notch will be positioned as shown in your first post, and will be 1 unit in width along the hypotenuse, and 1/2 unit deep, if you follow me?
  6. #16
    AutoCAD 2013
    Nov 2011
    6,056
    Quote Originally Posted by frankenstein19 View Post
    Does that mean that you have successfully located the notch along the hypotenuse?
  7. #17
    Full Member
    AutoCAD 2015
    May 2015
    39
    im sorrrrrrrrrrrrry! im just very confused! youre telling me to do the keyway in the top view. how do i know where to start? do i go to the front view and make a line at 3.00 and draw it upward so i know where the keyway starts? yess i do follow you with the dimensions of the rectangular notch!
  8. #18
    Full Member
    AutoCAD 2015
    May 2015
    39
    am i doing this right so far??
  9. #19
    AutoCAD 2013
    Nov 2011
    6,056
    No apology required.
    Just relax, breathe, everything is going to be okay.
    I now see that you have a nice representation of the overall shape in your modelspace.
    Are you showing us a 3D Solid object, or are those just lines or polylines?
    I am trying to get you to 3D Model it, instead of just drawing it.
  10. #20
    Full Member
    AutoCAD 2015
    May 2015
    39
    is the keyway ok? when i do the hi command i cant see the extrude on the keyway, like the depth of it. but then again when i di the extrude i just did it downward after i drew it on the top view. is that correct?
  1. Create a Drawing - Viewports problem
    By gnusselt in forum Autodesk Inventor
    Last Post: 21st Sep 2011, 04:01 pm
  2. Replies: 0
    Last Post: 31st Aug 2010, 10:50 pm
  3. One Raster Image, multiple viewports
    By Brian_63 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2009, 10:24 pm
  4. Scaling Viewports, image rotation, images in paper space
    By Jaco in forum AutoCAD Beginners' Area
    Last Post: 15th Apr 2004, 10:13 am
  5. is it possible 4 me 2 create a 3D image of pooh n autocad
    By madaryl in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Jan 2004, 02:08 pm
Tags for this Thread
