Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 76
  1. #21
    AutoCAD 2013
    Nov 2011
    5,995
    Quote Originally Posted by frankenstein19 View Post
    am i doing this right so far??
    No you are not there yet, BUT you are much closer than you have ever been before.
    The keyway is meant to be cut at a right angle from the hypotenuse, not the back face.
  2. #22
    Full Member
    AutoCAD 2015
    May 2015
    39
    those are all polylines/ im not showing you a solid object but its supposed to be a solid object at the end right? when i use the hide command right? i just have no idea what you mean by 3D modeling it.
  3. #23
    AutoCAD 2013
    Nov 2011
    5,995
    The HIDE command won't do anything to polylines. It works on 3D Solids though.
    I want to draw the triangle which you have already done, I hope as a closed polyline,
    and then locate the keyway PROPERLY, as shown in my last screenshot.
    STOP trying to draw all 3 views of it. Work with me on the TOP View.
    Please revert to a single viewport in your Modelspace, and set it to TOP view.
  4. #24
    AutoCAD 2013
    Nov 2011
    5,995
    Please watch this link
    http://www.cadtutor.net/tutorials/au...nd-press-pull/
    then we can get back to it, and you will much better understand what I am trying to help you to do.
  5. #25
    Full Member
    AutoCAD 2015
    May 2015
    39
    OK i think i fixed the keyway and made it perpendicular to the hypotenuse. it has a width of 1.00 and a depth of .50 and i extruded it from the top view
  6. #26
    Senior Member
    ttray33y's Computer Details
    Windows 7
    Dell Precision T3500
    XEON W3503
    16GB
    Quadro 2000
    1TB
    Dell 21" LED (DUAL)
    P&ID
    ttray33y's Discipline Details
    Process & Instrumentation Designer
    P&ID
    Design and check process diagram for consistency in accordance to PIP and company standard
    P&ID 2014
    Jun 2013
    Inside my head.
    123
  7. #27
    Full Member
    AutoCAD 2015
    May 2015
    39
    oh geez seeing yours makes me want to cry. i watched the video. when i tried using push and pull it would just do the same as extrude. do i move on to the circle now? and then do i trim whats overlapping?
  8. #28
    Senior Member
    Windows 7
    XEON W3503
    16GB
    Quadro 2000
    1TB
    Dell 21" LED (DUAL)
    P&ID
    P&ID
    P&ID 2014
    Jun 2013
    Inside my head.
    123
    practise + geometry + trigo = good drafter. IMHO
  9. #29
    AutoCAD 2013
    Nov 2011
    5,995
    Please do the following.
    Start the POYLINE command, and with your endpoint OSNAPS turned on, Trace over the TOP view in the upper left viewport.
    Don't draw the full hypotenuse, but follow the snaps which define the notch for the keyway.
    You will wind up with a triangle with the notch shaped bite taken out of it.
    You will then be able to use the EXTRUDE command to give it the depth of 4 units.
    Don't give up, we are almost there. You CAN do this.
  10. #30
    Full Member
    AutoCAD 2015
    May 2015
    39
    isnt that what i did?? ): i used polylines traced along the hypotenuse, i made the polyline 3.00 adn then i went up perpendicularly .50 then made a parallel line to the hypotenuse of 1.00 and then went down, then i extruded.
  1. Create a Drawing - Viewports problem
    By gnusselt in forum Autodesk Inventor
    Last Post: 21st Sep 2011, 04:01 pm
  2. Replies: 0
    Last Post: 31st Aug 2010, 10:50 pm
  3. One Raster Image, multiple viewports
    By Brian_63 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2009, 10:24 pm
  4. Scaling Viewports, image rotation, images in paper space
    By Jaco in forum AutoCAD Beginners' Area
    Last Post: 15th Apr 2004, 10:13 am
  5. is it possible 4 me 2 create a 3D image of pooh n autocad
    By madaryl in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Jan 2004, 02:08 pm
Tags for this Thread
