Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 76 of 76
  1. #71
    Full Member
    AutoCAD 2015
    May 2015
    39
    4 solids, so 12 viewports*
  2. #72
    AutoCAD 2013
    Nov 2011
    5,985
    Try using your VIEWPORTS configuration dialog, as shown in the screenshot, with VPORTS command.
    The views at the right were generated in a matter of seconds (I would never use all of them as they are redundant) using the VIEWBASE command, of which I have spoken.
    But they do not use viewports, so as you are meant to use viewports, you should do it the old school way.
    One day you might want to ask your instructor about VIEWBASE, as he may or may not even know about it.
    Or once you feel good about what you are working on, save a COPY of it, and using the copy, take the VIEWBASE command around the block. you'll be glad you did, even if it is not immediately intuitive. I also included a link a few posts back explaing it.
  3. #73
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    Quote Originally Posted by frankenstein19 View Post
    i am using angular and thats what its telling me. also is there a way to remove the lines that separate each view port without removing it?
    Your dimensions do not line up correctly with your geometry (that probably explains why they are incorrect). You have to relocate the origin of your UCS and also make sure it is oriented in the right direction. This can be done manually via the UCS command or by using the Dynamic UCS feature.
  4. #74
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    This is closer to what is depicted in the image of the object you were given to draw re: dimensioning. I just included a few of the dimensions for demonstration purposes.
    I used the Aligned dimension option for two of the dimensions (3.00 and 6.00). I also created a second dimension style so I could get a couple of the dimensions to display differently (2.00 and 4.00).
  5. #75
    AutoCAD 2013
    Nov 2011
    5,985
    Thanks ReMark, that's the ticket!
    I had thread fatigue, couldn't bear the thought of another ancillary can of worms, extended dissertation,
    having not even had my morning shower nor lunch at that point.
  6. #76
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    Well you did a good job Dadgad.
  1. Create a Drawing - Viewports problem
    By gnusselt in forum Autodesk Inventor
    Last Post: 21st Sep 2011, 04:01 pm
  2. Replies: 0
    Last Post: 31st Aug 2010, 10:50 pm
  3. One Raster Image, multiple viewports
    By Brian_63 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Feb 2009, 10:24 pm
  4. Scaling Viewports, image rotation, images in paper space
    By Jaco in forum AutoCAD Beginners' Area
    Last Post: 15th Apr 2004, 10:13 am
  5. is it possible 4 me 2 create a 3D image of pooh n autocad
    By madaryl in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Jan 2004, 02:08 pm
Tags for this Thread
