Hrki Posted May 20, 2015 Share Posted May 20, 2015 I hope you understand the problem explained in picture. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted May 20, 2015 Share Posted May 20, 2015 One way.... Draw a line PERP to the 51° line (in the NW direction in this case) Make it's length = to the radius of the arc. Move both lines. Using the far endpoint of the new line as the base point, and move to the center point of the arc. Erase new line, adjust the existing line for length. It is tangent. Quote Link to comment Share on other sites More sharing options...
rkent Posted May 20, 2015 Share Posted May 20, 2015 copy the arc any distance at 51 degrees, draw tan to tan, erase the arc. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 21, 2015 Share Posted May 21, 2015 Another copy line rotate 90 then put 1 end on center of arc intersecting pt is tangent point. Quote Link to comment Share on other sites More sharing options...
eldon Posted May 21, 2015 Share Posted May 21, 2015 Or draw a line from the Center of the red arc, perpendicular to the line. Move the line from the Endpoint of the new line to the Intersection with the red arc. Quote Link to comment Share on other sites More sharing options...
Hrki Posted May 21, 2015 Author Share Posted May 21, 2015 Or draw a line from the Center of the red arc, perpendicular to the line. Move the line from the Endpoint of the new line to the Intersection with the red arc. Thanks i will use your solution Quote Link to comment Share on other sites More sharing options...
rkent Posted May 21, 2015 Share Posted May 21, 2015 You can use parametrics, pick tangent, pick arc, pick line. Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 22, 2015 Share Posted May 22, 2015 OP says the angle cannot change. If that is the only restriction, simply moving or copying the line by the midpoint grip to the tangent snap will do it. We just had a nearly identical issue posted by another member yesterday, only they were having trouble finding the Tangent snap. D'y'all ever notice these things seem to come in bunches. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 22, 2015 Share Posted May 22, 2015 Why not another method UCS OB Ortho on Draw line from arc center past arc intersection point is tangent then UCS W. Quote Link to comment Share on other sites More sharing options...
rkent Posted May 22, 2015 Share Posted May 22, 2015 OP says the angle cannot change. If that is the only restriction, simply moving or copying the line by the midpoint grip to the tangent snap will do it. We just had a nearly identical issue posted by another member yesterday, only they were having trouble finding the Tangent snap. D'y'all ever notice these things seem to come in bunches. That won't work here, and I suspect it doesn't work for others which is the reason for other solutions. Parametric solution seems like the best to me, and quickest. Quote Link to comment Share on other sites More sharing options...
Dana W Posted May 22, 2015 Share Posted May 22, 2015 (edited) That won't work here, and I suspect it doesn't work for others which is the reason for other solutions. Parametric solution seems like the best to me, and quickest. It's against the laws of geometry for it not to work. If it isn't working then the line has crossed the curve and is intersecting at more than one point, or never got all the way to the curve. EDIT: We are dealing with AutoCad, a tangent snap point and a line being moved by its mid-point grip, at least I am. Edited May 23, 2015 by Dana W Quote Link to comment Share on other sites More sharing options...
