Results 1 to 6 of 6
    Senior Member BenGoble's Avatar
    BenGoble's Computer Details
    Windows 7 64-bit
    AMD Phenom II X4 920 Processor 2.80GHz
    4.0GB RAM
    ATI Radeon HD 3870 (512MB G-DDR4)
    Samsung HD103SI ATA Device
    SyncMaster 940BW
    3ds Max 2011
    Sep 2006
    London
    114
    Default Issues when working with wire frame models and extrude,loft, revolve commands...
    Basically I'm new to AutoCAD and I'm teaching myself. I'v been using the "extrude" and "loft" command and I'm having a problem with a lack of "faces" maybe??? I think it could be an issue with "SurfTab1" & "SurfTab2" but I'm not sure as I can't seem to change it. The second .jpg below shows the lofted version of the circles, however as it clear from the image it lacks lines! haha. Anyway if anyway can point me in the right direction with this I'd be very greatful!!!
    Oh sorry this is apparently how it is meant to appear (final image at bottom showing before and after lofting of a similar set of circles.)
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,483
    i'm not aware of a LOFT command.... is that something new in AutoCAD 2007? anyways, i know in previous versions, the EXTRUDE and LOFT (i'm assuming is the same as REVOLVE) command has nothing to do with the SURFTAB1/SURFTAB2 variables because when you EXTRUDE something, it's a solid - not a mesh. if you want to mess with the wireframe mode for Solids, try the ISOLINES variable. 20 is a good number to start with... also, try FACETRES for smoother objects/wireframe, etc.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Windows 7 64-bit
    4.0GB RAM
    SyncMaster 940BW
    3ds Max 2011
    Sep 2006
    London
    114
    Ahhh I'v discovered it was as simple as typing the "hide" command after performing the commands. Oh and 2007 has a loft command.
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,483
    oh you were meaning SHADEMODE's i guess. lol
  5. #5
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    The SURFTAB1 and SURFTAB2 variables apply only to surfaces and not to solids. For solids, look at the FACETRES variable if your solids are not smooth. Also, be aware that what you see (for example in wireline) is only a representation of the actual geometry and you will see it in all its glory when it is rendered.
    Styk, LOFT is new in 2007. In fact, 3D in 2007 is ENTIRELY different to what it was in previous versions.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,483
    yeah, i'd love to get my hands on a copy. at my job, we use blocks CONSTANTLY and i would love to have even AutoCAD 2006 for Dynamic Block capabilities.... im gonna hit them up for AutoCAD 2008 when/if it arrives... haha
    not much 3D work over here, but fun to have on my laptop so i can do it in my spare time.
  1. Convert wire frame to solid...
    By capac in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Apr 2010, 08:48 pm
  2. 3d wire frame or solid modelling?
    By comcu in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Aug 2006, 07:43 pm
  3. Wire frame density
    By daniel.dascalu in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2006, 06:23 pm
  4. 3D solids out of wire frame drawings
    By Ari in forum AutoCAD Beginners' Area
    Last Post: 30th Jan 2006, 02:18 pm
  5. 3d wire frame and surface modelling
    By allanp in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Sep 2005, 08:51 am
