i'm not aware of a LOFT command.... is that something new in AutoCAD 2007? anyways, i know in previous versions, the EXTRUDE and LOFT (i'm assuming is the same as REVOLVE) command has nothing to do with the SURFTAB1/SURFTAB2 variables because when you EXTRUDE something, it's a solid - not a mesh. if you want to mess with the wireframe mode for Solids, try the ISOLINES variable. 20 is a good number to start with... also, try FACETRES for smoother objects/wireframe, etc.
Ahhh I'v discovered it was as simple as typing the "hide" command after performing the commands. Oh and 2007 has a loft command.
