chrisdarmanin Posted May 21, 2015 Share Posted May 21, 2015 hi guys, in the attached drawing in the red square there are some objects that i cannot select. problem drawing.dwg the drawing (in the red square) was first drawn in 3d, then flatshot to change it to 2d. when i imported it into other drawings it started becoming unselectable and could only select it via vpmax from paperspace. i audited the drawing and tried recover on the drawing. i tried to save it to dwg r12 and then save it back to dwg 2013 but nothing is making a difference, and its driving me crazy. any opinions or help on the matter? thanks in advance Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 21, 2015 Share Posted May 21, 2015 You mean these objects in the red rectangle that I selected and changed their color to yellow? Quote Link to comment Share on other sites More sharing options...
steven-g Posted May 21, 2015 Share Posted May 21, 2015 I see the behavior, if I do a selection of any other objects and then hit ESC the offending objects vanish; You can select them with the command "select" "all", and again after ESC they vanish, I did manage to fix the drawing using a flatten macro, but there is no visible indication as to why there was a problem to start with in either the properties or using the list command, other than all the objects are not oriented to the UCS. Attached is the fixed drawing. problem drawing1.dwg Quote Link to comment Share on other sites More sharing options...
chrisdarmanin Posted May 21, 2015 Author Share Posted May 21, 2015 thanks guys i continued searching and found this http://forums.augi.com/showthread.php?85640-Unselectable-Objects (see reply 3) seemed to fix it.... thanks again Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 21, 2015 Share Posted May 21, 2015 Which solution did you use? I did not have to do anything like either of the solutions that were mentioned in that thread. I merely changed my view to SE isometric. Quote Link to comment Share on other sites More sharing options...
chrisdarmanin Posted May 21, 2015 Author Share Posted May 21, 2015 Which solution did you use? I did not have to do anything like either of the solutions that were mentioned in that thread. I merely changed my view to SE isometric. hah!! that was easy!!!!! worked for me too!! Quote Link to comment Share on other sites More sharing options...
