Batch replace the attribute value
DuanJinHui
Dear.All
Before, I had requested a thread at here:
http://www.cadtutor.net/forum/showthread.php?90216-Replace-the-attribute-value&highlight=DuanJinHui
(defun c:TesT (/ st ss)
 ;; Tharwat 25.12.2014    ;;
 (if (and (/= "" (setq st (getstring t "\n Specify new value :")))
          (princ "\n Select Attributed blocks ...")
          (ssget "_:L" '((0 . "INSERT") (66 . 1)))
   (vlax-for x (setq
                 ss (vla-get-ActiveSelectionSet
                      (vla-get-ActiveDocument (vlax-get-acad-object))
     (mapcar '(lambda (a)
                (if (eq (strcase (vla-get-tagstring a)) "DR_DATE")
                  (vla-put-textstring a st)
             (vlax-invoke x 'getattributes)
 (if ss
   (vla-delete ss)
)(vl-load-com)
Mr.Tharwat helped me.
But this can only replace one attribute value (TAG=“DR_DATE”)
If I want replace another attribute value . I need modify the source code. :(
I have a idea. use dialog to choose Tag and modify attribute.
Here is DCL code . I don't know coding this .
I need help ! I really appreciate it.
BRA:dialog {
   label = "Batch Replace Attribute" ;
   :boxed_row {
       label = "TAG" ;
       :column {
           :radio_button {
               key = "K1" ;
               label = "TAG1" ;
           :radio_button {
               key = "K2" ;
               label = "TAG2" ;
           :radio_button {
               key = "K3" ;
               label = "TAG3" ;
           :radio_button {
               key = "K4" ;
               label = "TAG4" ;
           :radio_button {
               key = "K5" ;
               label = "TAG5" ;
           :radio_button {
               key = "K6" ;
               label = "TAG6" ;
           :radio_button {
               key = "K7" ;
               label = "TAG7" ;
           :radio_button {
               key = "K8" ;
               label = "TAG8" ;
   :spacer {}
   :edit_box {
       key = "Val" ;
       label = "Value:" ;
   :spacer {}
   :row {
       ok_cancel;
