Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member 3dwannab's Avatar
    3dwannab's Computer Details
    Windows 7 Ultimate x64
    Self-Built
    Rampage II Extreme
    Intel(R) Core(TM) i7 CPU 965 @ 3.20GHz
    Corsair 12GB DDR3 XMS3 PC3-12800C9 1600MHz
    ATI Radeon HD 4870 X2
    512GB SSD
    2 x WD VelociRaptor 1000 GB Hard Drives @ 7,200RPM
    32" HP LP3065 Wide LCD Moniter + 24" Dell
    Architectural
    3dwannab's Discipline Details
    arch technician and arch viz
    Architectural
    Office Tea Maker
    AutoCAD 2017
    Jun 2012
    Ireland
    162
    Default Select objects in current layer
    Code:
    (sssetfirst nil (ssget "_X" '((8 . "5"))))
    will select objects in layer 5 no problem but when i incorporate
    Code:
    (getvar "CLAYER")
    to make:
    Code:
    (sssetfirst nil (ssget "_X" '((8 . (getvar "CLAYER")))))
    It comes back with error: ; error: bad SSGET list value
    It's probably just a simple fix (heck, maybe even a standard command to do the same)
    Thanks in advance.
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    See if you can work out why from my tutorial The Apostrophe and the Quote Function
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Self-Built
    Rampage II Extreme
    512GB SSD
    Architectural
    Architectural
    Office Tea Maker
    AutoCAD 2017
    Jun 2012
    Ireland
    162
    Quote Originally Posted by Lee mAC View Post
    mAC;633024]See if you can work out why from my tutorial The Apostrophe and the Quote Function
    Sorry, maybe having a slow day but I can't get that to work. Have tried which seems like the most logical solution:
    Code:
    (setq ss (getvar "CLAYER"))
    (sssetfirst nil (ssget "_X" '((8 . (list ss)))))
    from this example:
    Code:
    _$ (setq x 5)
    5
    _$ (list 1 2 3 4 x)
    (1 2 3 4 5)
    I'm learning maxscript also and find it much more user friendly to learn.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,559
    Refer to the ssget example in this section - remember that any expression following a quote/apostrophe will not be evaluated.
  5. #5
    Self-Built
    Rampage II Extreme
    512GB SSD
    Architectural
    Architectural
    Office Tea Maker
    AutoCAD 2017
    Jun 2012
    Ireland
    162
    Quote Originally Posted by Lee Mac View Post
    Thanks. Maybe my brain isin't all there today but looking at your example didn't help. I still know you're the LISP master
    I found this link here in the help: http://exchange.autodesk.com/autocad...7a53f-7a31.htm
    I've came up with three variations which do the same thing
    Code:
    (setq lay_name (getvar "CLAYER"))
    (setq ss1 (ssget "_X" (list (cons 8 lay_name))))
    (command "pselect" "P" "")
    (setq ss1 (ssget "_X" (list (cons 8 (getvar "CLAYER")))))
    (command "pselect" ss1 "")
    Thanks for your help.
  6. #6
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    813
    Quote Originally Posted by 3dwannab View Post
    Code:
    Glad you found a solution, but Lee's link explains the quote function as well as any I've seen. Do you understand now that the difference between using quote -vs- the list and cons functions is that any expression following a quote/apostrophe will not be evaluated?
  7. #7
    Self-Built
    Rampage II Extreme
    512GB SSD
    Architectural
    Architectural
    Office Tea Maker
    AutoCAD 2017
    Jun 2012
    Ireland
    162
    I do to some degree it will sink in eventually. I don't know want has happened but NONE of the examples I had working are working now. Commandline is now saying "Unknown command "PSELECT". Press F1 for help." All those were working perfectly beforehand.
    My lisp so far.
    Code:
    (defun c:SEL_LAYER_CURRENT ( / cmdecho )
        (setq  cmdecho (getvar 'cmdecho))
        (setvar 'cmdecho 0)
        ;;(princ (strcat "\n" (sslength ss1) " objects selected. "))
        ;;(print (sslength ss1))
        (setvar 'cmdecho cmdecho)
    I also want to print the amount of selected objects after the command has finished but I having trouble joining up the text string and the amount of objects.
  8. #8
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,224
    Eg.
    Code:
    (defun c:Test (/ s)
      (if (setq s (ssget "_X" (list (cons 8 (getvar "CLAYER")))))
        (princ (strcat "\nNumber of Found objects : < " (itoa (sslength s)) " >"))
      (sssetfirst nil s)
    Self-Built
    Rampage II Extreme
    512GB SSD
    Architectural
    Architectural
    Office Tea Maker
    AutoCAD 2017
    Jun 2012
    Ireland
    162
    Quote Originally Posted by Tharwat View Post
    Eg.
    Code:
    (defun c:Test (/ s)
      (sssetfirst nil s)
    Excellent Tharwat. I understand fully what all that code does. (I thought I tried itoa to convet it to a string!!) Thanks very much. I think this simple routine will take over the LAYWALK command for me. BTW it could be useful of it allowed the user to have the dialog open. Anyway this is great. Here's the code.
    Code:
    ;;---------------=={ 3DwannaB_Sel_Layer_Current.lsp }==-----------------;;
    ;;  Selects All Objects On Current Later                                ;;
    ;;  Author: 3DwannaB, Copyright © 2015                                  ;;
    ;;  Version 1.0    -    23-05-2015                                      ;;
    ;;  First Release. Lots of help from 'Lee Mac' Credit goes to 'Tharwat' ;;
    ;;  See http://bit.ly/1HzZrlM                                             ;;
    (defun c:SEL_LAYER_CURRENT (/ s cmdecho )
        (setvar 'cmdecho 0)
        (sssetfirst nil s)
    (princ
        (strcat
            "\n:: 3DwannaB_Sel_Layer_Current.lsp | Version 1.0 | by 3DwannaB  ::"
            "\n:: Type \"Sel_Layer_Current\" to Invoke                          ::"
    ;;                             End of File                              ;;
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,224
    You are most welcome .
    Can you tell me what is the need of the System Variable CMDECHO into the routine ?
  1. select all objects on the current layer
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Dec 2015, 03:53 pm
  2. Select all objects in a single layer: how?
    By Sudan in forum AutoCAD Beginners' Area
    Last Post: 15th Sep 2015, 08:21 pm
  3. Select All Objects on a Certain Layer
    By resullins in forum AutoCAD General
    Last Post: 28th Dec 2011, 01:22 am
  4. Setting objects to current layer.
    By roberts in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Apr 2007, 04:55 pm
  5. Select Objects - Place on new layer.
    By FindAPath in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Aug 2006, 10:37 pm
Tags for this Thread
