Results 1 to 4 of 4
    Senior Member
    AutoCAD 2014
    Sep 2007
    112
    Question Revit Beginner - Linking files
    Hi
    I work for an engineering consultant who is stepping into the Revit mine field for the first time. I have limited experience in using revit but no experience at all regarding the linking of the various engineering disciplines.
    We will be having electrical, mechanical, structural and civil engineers working on the model at various offices. There will also be external architects involved along the course of the scheme as well, again who will be based outside of our office.
    What is the most suitable way to link each discipline where you can only alter your own discipline elements?
    What is the best way to back up and save files?
    Anyone got any procedures for carrying this out please that would be much appreciated.
    Thanks
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    First and foremost, read up on Worksharing, Central Models and Local Files:
    http://help.autodesk.com/view/RVT/20...9-86D73EB9C048
    Worksharing is best bet for a collaborative environment. This will allow you to set the number of backups in which you can roll back to if needed. Your local model also provides an extra layer of protection. There isn't an "auto-save" feature like AutoCAD, but there is a notification feature that allows you to voluntarily save upon the frequency you set.
    Linking Models can be found here, and is straight forward:
    http://help.autodesk.com/view/RVT/20...4-A8BF488C728D
    Also, preceding Linking it's best to become familiar with Shared Positioning (aka Shared Coordinates) to keep models aligned:
    http://help.autodesk.com/view/RVT/20...C-A348955AB49C
    In AutoCAD there is a hard coded WCS that never changes between drawings. So to align projects you have to physically select everything and move it to an absolute WCS coordinate. In Revit, the origin is manually positioned every time and it can (and should) reflect the physical geographical location. But, this is all relative to what's already been established from the architect.
    Since you're starting out I'd suggest a basics training course for your office, or a Revit Essentials book which can be found on Amazon.com. Happy Revit'ing!!
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Senior Member
    AutoCAD 2014
    Sep 2007
    112
    Question
    Thanks tzframpton
    One thing that is confusing is where is teh best location to save the central file?
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,115
    Network location, in a Job Folder. If you will be Worksharing with people in a WAN environment, have your I.T. department look into installing and setting up Revit Server.
  1. linking .idw files to my .iam
    By Bristang in forum Autodesk Inventor
    Last Post: 2nd Apr 2015, 08:11 pm
  2. Project Set-up. Linking files
    By Nick-H- in forum Revit MEP
    Last Post: 26th Apr 2013, 03:50 pm
  3. Linking 2D dwg files to revit mep 2011
    By watapatata in forum Revit General
    Last Post: 8th Mar 2012, 01:35 pm
  4. Linking Revit to SQL
    By Trevit in forum Revit General
    Last Post: 27th Nov 2010, 10:27 am
Tags for this Thread
